Old 16-03-10, 06:25 PM   #11
RobH13
Default Re: Clutch cover oil leak.
Originally Posted by hardhat_harry View Post
The loctite rubber gasket sealant is the business and works everytime cant remember the ref number unfortunatley but Halfords stock it
I've got the same issue and just had a trip to Halfords to search for the rubber gasket, but couldn't find that particular product, do you know if this is the correct name ?
Rob.
Old 16-03-10, 06:54 PM   #12
5hort5
Default Re: Oil Leak
Originally Posted by mjc View Post
and finally if you have the bike on the sidestand theres no need to drop the oil, the level should be below the clutch cover at this angle.
cheers
You learn something new every day on this site
5hort5 is offline   Reply With Quote
Old 16-03-10, 07:00 PM   #13
5hort5
after a quick rummage in a garage:
loctite 5910 premium black silicone - High performance Gasket maker/sealant
http://www.halfords.com/webapp/wcs/s...egoryId_165691
comes in a small cardboard box about 20cm tall, £5.50 so not massively expensive but good stuff, used it on the valve covers and the clutch cover now.
Old 16-03-10, 07:02 PM   #14
beabert
I loctited mine, and its leaking again grrrr, very slowly though, ill try again.
Old 17-03-10, 06:26 AM   #15
RobH13
Nice one,
Rob.
Old 17-03-10, 10:40 AM   #16
Neeja
If anyone needs a (definitely not leaking) clutch cover, I've got one sat in me garage. Still has the O-ring gasket that fits well.
Old 17-03-10, 08:40 PM   #17
Geodude
Geodude's Avatar
What year, what price and is it the metal insert in the bolt holes one as im sick of fixing my leak
Old 18-03-10, 04:15 PM   #18
Neeja
It's for a curvey, so it's just the black plastic plate that can be taken off idependantly. If you need the entire side-cover then I've got one too...I'm not sure if it'd fit on a pointy but the engine is apparently quite similar, and it'd let you take the clutch cover off without having to take the whole shebang with it. Hmm.
Old 18-03-10, 04:21 PM   #19
Geodude
Geodude's Avatar
Yep just the plastic clutch cover for curvy, but is it the one with the metal inserts in the bolt holes?
Clutch cover oil leak. dmandub SV Talk, Tuning & Tweaking 12 19-02-10 01:37 AM
clutch cover seal (oil leak) sv-smc SV Talk, Tuning & Tweaking 9 31-01-10 06:47 PM
The never ending clutch cover oil leak badger-666 SV Talk, Tuning & Tweaking 3 20-02-08 07:25 PM
leak from right-hand crankcase/side cover- common problem ? chriskk SV Talk, Tuning & Tweaking 9 09-10-07 11:27 AM
Curvy SV650 clutch cover oil leak bugsy46 Bikes - Talk & Issues 1 06-04-07 11:28 PM
