Old 18-03-10, 12:29 PM   #11
ophic
ophic's Avatar
Default Re: Clutch lever suggestion - achey hand?
Originally Posted by phi-dan View Post
Would bending the lever (after suitable application of heat) be a workable idea?
If this is completely wrong and/or dangerous, then mods please delete or edit with "FFS NO!" or some such!
pointless imho. You'd just add some material to the lever stop position if you wanted the lever to stop closer to the bars - and adjust the cable accordingly
Silver SV650SK3, Fuel exhaust
Old 18-03-10, 12:54 PM   #12
phi-dan
phi-dan's Avatar
when you put it like that
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 18-03-10, 08:06 PM   #13
Red Herring
Red Herring's Avatar
Have you checked to make sure the cable is running free and not binding as this would add considerably to the effort needed. The problem is it would be easy to swop the clutch lever assembly with that from another bike which has a shorter action (and can therefore be adjusted nearer to the bar) but in order to still get the travel at the clutch basket that clutch lever would have to have a higher ratio, which in turn would make it even heavier.
The other thing you can consider, and this might sound a bit radical, is fitting a quick shifter. This would allow you to change up the box without touching the clutch at all (Yes I know lots of people can do that anyhow without a quickshifter) which would save you at least some, if not half, of your clutch actions.
Old 18-03-10, 10:47 PM   #14
sam anon
When sat at lights etc I make sure I have my lever held as close to the end as possible to get as much leverage as I can.
Might this help?
Old 19-03-10, 06:15 PM   #15
Shadow
My sv1000 has a hydraulic clutch, its about the lightest one ive used on a bike.
The r6 has a cable, which i recently changed for a new one plus oiled it up before putting it on.
Thats made a huge difference to the weight at the lever.
A cable is only £10, plus a few drops of oil, work it through, then repeat.
Thats were i would start, before looking at aftermarket levers and the like.
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch Bayside GTR Stuff Wanted 5 23-11-07 11:54 AM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
clutch lever and front brake lever Quiff Wichard For Sale - SV's and SV related items 4 19-03-07 12:05 AM
