#11 |
The front cct is at its final click
#12 |
Double check again IMO just to check it didn't drop a few clicks as you pulled it out. Feel how much friction there is in the mechanism to see whether this is likely.
(just double check before firing into replacing camchains)
#13 |
I just got a but kicking for not setting the cam to TF and the fear of dropping a tooth so took out the plugs and turned the engine over by hand to check.
Now ive got to check the time he said its 21 teeth back? |
#14 |
You put tensioner back in to turn it right?
#15 |
Yeah i put it back in then the spring and bolt heard it click lots then turned the crank 360 degrees
K3 cam chain tensioners | widget | Stuff Wanted | 0 | 24-08-10 04:46 PM |
cam chain tensioners | hkhksh | Bikes - Talk & Issues | 7 | 19-02-10 08:35 AM |
Cam chain tensioners on a K3 | lukemillar | SV Talk, Tuning & Tweaking | 5 | 19-09-06 11:28 AM |
Cam chain tensioners | northwind | SV Talk, Tuning & Tweaking | 16 | 05-01-05 06:33 PM |
Cam Chain tensioners on a K3.. anyone?? | valleyboy | SV Talk, Tuning & Tweaking | 7 | 26-12-04 12:55 PM |
