Old 07-09-10, 06:52 AM   #11
maxinc
Default Re: SV650S comfort kit fitted - clutch cable problem.
This may be obvious but have you tried adjusting the cable at the other end (engine end). I have found on mine that with the new route the clutch cable become very tensioned and the lever adjustment range just wasn't enough. Once I relaxed the other end, everything fit comfortably with some room to spare at both ends.
Old 07-09-10, 05:55 PM   #12
andycj
Thanks for the idea but, I think I'm going to go with a "naked" clutch cable, just seems to be the most common solution, easy and cheap too.
Old 07-09-10, 09:07 PM   #13
Jayneflakes
Jayneflakes's Avatar
Originally Posted by madness View Post
I didn't like any of the many cable routes I tried. I ended up swapping it for a DL650 cable (£10 from Wemoto) which if anything is a tad long.
I have just done this on my conversion and with my extra high risers, it works perfectly. Thanks Madness for the tip.
Jayne you're a Pussy Magnet
Clutch Cable silent11 SV Talk, Tuning & Tweaking 4 29-09-09 02:44 PM
SV650S K2 Clutch actuator problem(?) ssurprize SV Talk, Tuning & Tweaking 7 19-07-09 07:04 PM
New Clutch Cable SV650s curvey SOLD svscratcha For Sale - SV's and SV related items 3 22-04-09 04:44 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Clutch cable 21QUEST For Sale - SV's and SV related items 1 03-04-06 12:03 AM
