Old 24-10-10, 08:20 PM   #11
Default Re: HELP! GSXR Shock Fitted but bike sits 60mm lower ????
i thought to increase hight you fitted shorter dogbones?
Old 24-10-10, 08:24 PM   #12
husky03
yep
Old 24-10-10, 08:27 PM   #13
leebex
sorry, cack info, luckily you know what i meant
Old 25-10-10, 07:35 PM   #14
Default Re: GSXR shock fitted but bike sits 60mm lower?
what did you expect?
You probably won't be able to get the height back with dogbones, and it isn't IMO a good idea as you're making the system a hell of a lot more progressive.
Plus for good handling you need a massive amount more ride height than stock. 355mm or so at shock on stock dogbones.
Old 25-10-10, 07:55 PM   #15
barwel1992
YC does lowering the front have exactly the same effect as raising the rear ? or should one be balance with the other
Old 25-10-10, 08:19 PM   #16
Ground clearance and swingarm angle are just as important as rake and trail. If you lower the front 60mm because your shock is too short you just created two problems rather than fixing one!
Old 25-10-10, 08:21 PM   #17
barwel1992
cheers didn't know that
ps wasn't suggesting it to the op was wondering about my own bike
gsxr600 k4 shock fitted skeetly SV Talk, Tuning & Tweaking 9 08-04-09 10:11 AM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
Gsxr k6 Shock - quick question *fitted dotted SV Talk, Tuning & Tweaking 8 10-11-06 10:07 AM
Fitted my Penske Shock TSM SV Talk, Tuning & Tweaking 4 17-04-06 08:05 PM
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) alien19779 For Sale - SV's and SV related items 0 28-03-06 01:16 PM
