#11 |
Dave
Maybe worth having a look at Barwel's rebuild thread http://forums.sv650.org/showthread.php?t=151525
#12 | |
Thou is easier. Just buy complete GSXR front end that is K1 or newer (not sure about K8 and later) and bolt it on.
#13 |
next question can you anodise both "tubes" on the forks or would this effect the working of them in anyway
also bottom yoke |
#14 |
What you mean? Inner and outer?
Outer of USD maybe, it is turned so might be OK, casting of a right way up fork is poor, castable alloys do not tend to anodise well. Lots of micro porous crap there... ano will transfer fingerprints into finish so it picks up all that stuff. Same with bottom yokes. That same micro porous crap tends to hold powder coating really well though ![]() For stanchion (shiny bit) you can get couple of coatings to reduce stiction. Old GSXR had pink or something, they were crap, 2001 had gold, they were OK not brilliant, 2008 or something has black coating and are OK. Aftermarket coatings are supposedly excellent to reduce stiction but it is tiny difference and if you got to ask you can't afford it.
#15 |
#16 |
I have a pair of Hayabusa forks that have sat in my workshop for a couple of years, offers??
#17 |
what about a pair of street triple forks?
#18 |
Dorsodoso forks, make a SV650SM
#19 |
Once again, cheap and readily available?
#20 |
the prilla forks i have are good but not a straight swap as the head tube is like 30mm so you have to have a sleeve welded in and then the sv stem pressed in
mine were £450 inc wheel disc's and brakes, yokes and forks inc risers and drilled yoke so stuf is out there to be had if you look hard enough |
Front forks - to GSXR or not to GSXR? | tom46 | SV Talk, Tuning & Tweaking | 13 | 23-06-10 02:27 PM |
Fitting GSXR front mudguard to GSXR USD forks | maviczap | SV Talk, Tuning & Tweaking | 1 | 20-02-10 10:05 PM |
Yob versions......why? | metalhead19 | Idle Banter | 2 | 09-12-09 10:42 PM |
Naked Curvy with RWU GSXR 600 forks? | wayniac | SV Talk, Tuning & Tweaking | 14 | 19-10-09 08:52 PM |
GSXR 750 k4 wheel with GSXR 600 K7 forks | Bunks | Bikes - Talk & Issues | 12 | 05-05-09 06:36 PM |
