Old 04-04-11, 05:12 PM   #11
muzikill
muzikill's Avatar
Default Re: Allen key screws rouding off - what to do next?
Cutting a slot in it wont be easy, am i right in thinking that the bolt is recessed?
Old 04-04-11, 07:14 PM   #12
Big Bad Al
Big Bad Al's Avatar
plus one for the torx tip - I have done that myself on the same bolt holding the grey infill panel and it worked a treat. I use copper ease always and the bolt was still too tight, hence the rounding. Good tip.
SFV650 in black with Evotech tailtidy, R&G Aeros and Heated Grips, Puig fly screen, Pipe Werx GP style race exhaust. Whoop!
Previously.... Black SVS - DHM's Heated Grips Airblade Iridium Double Bubble Screen Beowulf end can and Evotech tailtidy. 3/7/2004 - 26/6/2015.
Big Bad Al is offline   Reply With Quote
Old 05-04-11, 08:25 AM   #13
warmshed
I had to run a tap through that thread on my son's bike when I removed the panel. the bolt was very tight when removing it, copperslip/PBC is a must when replacing bolts. Good luck removing your bolt.
Old 05-04-11, 05:10 PM   #14
skithepowder
Cheers for all the advice guys, yeah without going and taking a look I think cutting a slot in the inpanel alllen bolt would be very difficult! At the moment, that one is still working, but I think I might have a look into the torx thing as I'm sure it's gonna round off soon, you can feel it slipping 1/2 the time. The exhaust one, not too important at the moment, cos it's loud enough for me with the baffle, but it'd be nice to know what it's like without! I like the idea of tightening a bit first to break the seal, will defo give that a go in future!
little gromits that fill the allen screws in the mirrors badsaboy Stuff Wanted 3 02-07-10 10:50 PM
help - rounded off allen bolt. New Leaf Bikes - Talk & Issues 31 29-01-09 10:28 PM
Rounded allen bolt svrob Bikes - Talk & Issues 11 05-07-08 07:09 AM
Seized allen bolt FishyMug SV Talk, Tuning & Tweaking 6 16-10-07 10:19 PM
Allen/Hex Key Set for SV650S Bud SV Talk, Tuning & Tweaking 8 20-02-05 05:54 PM
