Old 27-04-11, 09:45 PM   #11
klu
Default Re: Has anyone stubbied a Scorpion can?
Don't know if the can on my bike came stubbied from the factory or was a homemade jobby, but it looks and sounds amazing!
Old 27-04-11, 09:48 PM   #12
Default Re: Has anyone stubbied a Scorpion can??
Originally Posted by paiste View Post
Can you remember what size rivets you used/ ie grip range. I've measured the flange on the scorpion and it measures 6.0mm working on the basis that the flange is twice the size of the hole I'm guessing I'll need a 3.2mm rivet but I'm not sure what length
3.2x6mm grip length is 1.7-3.2mm and 3.2x8mm grip length is 3.3-4.8mm.
Didn't give a toss about the viper on my curvy but I want to make a good job on the scorpion. In fact I'm a bit worried about cutting the can as I'm not sure I'll get a good finish where it's been cut.
Its only 2 thin sheets of metal so dont need a long rivet.
Ralph gave me some which i used, as long as you have about a third sticking out once its gone through both sheets of metal, thatll be fine imo.
If you wanna neat cut, i would cut a piece of 18 thick plywood the same shape as the inner of the can and put it in there snugly the other side of the cut so that the good part is supported, if you undertsand that ?
Old 27-04-11, 10:08 PM   #13
paiste
Thanks Phil. I'll take a deep breath and make the cut!
Old 27-04-11, 10:10 PM   #14
paiste
I think that's a street extreme. They sound great. I think Binky has one on his rat bike.
Old 29-04-11, 11:25 PM   #15
stew
use stainless rivits if you can.
my father-in-law and i stubbied my blueflame i didnt like the length so asked him to chop a couple of inches off.
he cut it in half
<---- look here
when you get it all apart and decide the length you want put insulation tape round the can/sleeve gives you a nice guide to cut round so you dont get a wiggerly line.
Old 01-05-11, 11:08 PM   #16
paiste
Originally Posted by carelesschucca View Post
You should be fine with it.
But if you make a mess of it theres still a Yoshi Tri oval can up here in Scotland going cheap Still not been put up for sale yet.
Well I made a right royal **** up of stubbying the can. So annoyed, ruined a brand new can just to lose 4 inches. If I can't rescue of do you still have the can going cheap?
Old 01-05-11, 11:35 PM   #17
stew
what went wrong?
put some pics of the probs might be able to sort it.
the blueflame evo that i stubbied was a right pain in the bum as it has twin exit so the inside tube had to heaverly modified/cut and welded to make it fit back together didnt think about it till we choped the sleeve
took 4 hours to fettle it.
Old 02-05-11, 06:48 AM   #18
Dan, post up some pics, if you've only chopped 4 inches, there's plenty to play with.
Old 02-05-11, 09:48 AM   #19
paiste
Yeah will do. I've got to do the bank holiday family thing today, maybe I'll get a chance later. I'm sure it's not completely ruined, I was just having a Diva strop In the words of Stoner my ambition obviously outweighed my talent.
What's happened is as I've made the cut it's deformed the shape of the can and I cant get the end piece back in and I've rippled the end trying to force it in. I'm sure if I cut ann extra few cm's off It can be rescued. Just that I don't think I have the ability to do it being a ham fisted oaf that I am
Old 02-05-11, 10:17 AM   #20
Its common i think Dan for the middle to be a slightly different shape to the ends anyway Dan so dont worry.
Did you put a wooden piece in the inside as you cut it to stop it deforming?
If you wanted to slightly flare the end to get the end cap on, you could make or use wooden former inside but taper the edge by a few degress, then tap it in, this should give you a few extra mm's hopefully.
Clean and stubbied Brettus Photos 18 03-06-09 04:21 PM
Stubbied a can plowsie SV Talk, Tuning & Tweaking 32 19-09-08 01:52 PM
Akrapovic stubbied Lozzo Photos 27 29-04-08 07:45 AM
getting my can stubbied how long shall i make it jans1971 Bikes - Talk & Issues 4 22-04-08 05:12 AM
Stubbied Akrapovic Lozzo Photos 19 12-04-08 10:15 PM
