Old 27-10-11, 08:23 PM   #11
Dean-J
Default Re: Headlight Upgrade?
Pics?
Old 27-10-11, 08:24 PM   #12
CodeJACK
http://easternbeaver.com/Main/Produc...s/h4_kits.html
One of these kits is a much better option I think. Combine one of these with new bulbs and you'll see into other dimensions etc.
CodeJACK is offline   Reply With Quote
Old 27-10-11, 08:57 PM   #13
Dean-J
Thats exactly what i was talking about. but no way on earth id be paying 55 dollars plus delivery for something that can be made for less than a tenner...
Old 27-10-11, 09:13 PM   #14
Stonesie
My upgrade cost about £35, then again I used 3 relays and covered all the wiring in heat shrink to make it look like a pro job, fitted my Nautilus horn while I was at it.
Old 27-10-11, 09:17 PM   #15
Dean-J
Im assuming you went out and bought relays and all your components from a shop rather than simply pull em out of a car at the scrappies
I, luckily, tend to have everything i need to make looms kicking about the garage/workshop, so never really costs me anything but time
Old 27-10-11, 10:00 PM   #16
Stonesie
Aye I bought everything new from vehicle wiring products, the voltage drop went from about 2.5v to 0.17 so it made quite a differance to the light output.
Old 28-10-11, 10:07 AM   #17
alfa.rbt
I've just fitted osram nightracers to my curvy and it is good improvement for 20 quid.
Old 28-10-11, 11:01 AM   #18
Epic Monkey
Can you safely fit a higher wattage bulb? I know they said off road and rally use only, but are there any dangers to fitting it to the bike? Assuming it would generate more heat, but would it be enough to melt/damage anything?
Old 28-10-11, 11:18 AM   #19
maxinc
The wire harness may take it but I would say there is a fair chance of doing some damage to the reflector housing. Halogen incandescent bulbs are very inefficient light sources generating 10-20% light and 80-90% heat. The temperature of the bulb will increase much rapidly than the light output so I wouldn't put anything more than what the manufacturer specified.
Old 28-10-11, 12:43 PM   #20
Epic Monkey
Thanks Maxinc.
Headlight wireing upgrade + Nautilus Stonesie SV Talk, Tuning & Tweaking 1 26-02-11 08:53 PM
Headlight Upgrade AnotherFool SV Talk, Tuning & Tweaking 33 26-07-10 02:02 AM
Upgrade Headlight Bulbs, Which ones? cbay SV Talk, Tuning & Tweaking 39 27-01-10 01:03 PM
HID headlight upgrade - curvy GavinD SV Talk, Tuning & Tweaking 12 17-07-09 06:54 PM
HEADLIGHT BULB UPGRADE SV650S csimmo SV Talk, Tuning & Tweaking 8 26-04-05 01:55 PM
