Old 07-01-12, 11:56 AM   #11
muzikill
muzikill's Avatar
Flipping heck!... Just opened the parcel from wemoto. Ok they are the right shoes but one of the shoes doesnt have the wear line cut in the middle where the other side set does. Will this affect the braking?
The shoe on the far right........
http://www.wemoto.com/parts/picture/MS-S1435/
........... you get yourself all sorted to get a job done ... oh well!
Old 07-01-12, 12:41 PM   #12
Default Re: New pads 2nd opinion needed
don't open it and send it back...
Old 07-01-12, 01:16 PM   #13
gixer1
i put these gold fern on my 2004 gsxr 1000 and 1990 rgv 250 and they squeek on both bikes
on the front bit annoying they are good on the rgv but not on the gsxr i will be putting ebc
on it next time
Old 07-01-12, 01:21 PM   #14
muzikill
muzikill's Avatar
Thought so, ill email them first and let them know I dont want them to send another bad set. Ta bud.
Old 07-01-12, 09:05 PM   #15
Stenno
I went for HH at the front and GG at the back as I kept locking up the rear tyre in 'emergencies' i.e. bad riding. Albeit it's more down to my lack of riding experience rather than them being too harsh.
Old 10-01-12, 09:10 AM   #16
Roberrrrt
Wonder if the same principal applies to my pointy then - I've got GSXR callipers up front with more stopping power, and wemoto only stock HH pads for these. Question is - do I put HH or GG in my standard SV rear?
Old 11-01-12, 07:05 AM   #17
Spanner Man
Have you tried adjusting the height of the rear brake pedal?
Often when people lock up the rear on occasion, a small adjustment of the pedal height stops the issue. As it gives more 'feel'.
Cheers.
Spanner Man
Old 11-01-12, 09:50 AM   #18
GG
Old 11-01-12, 11:35 AM   #19
Stenno
Cheers.
Cheers, hadn't considered that. I'll give it a go!
Tools - opinion and help needed alfa.rbt Bikes - Talk & Issues 75 20-01-12 07:45 PM
changing rear brake pads- what's needed? Goldy SV Talk, Tuning & Tweaking 8 17-03-11 03:04 PM
brake pads needed k31tha Bikes - Talk & Issues 0 20-07-09 05:11 PM
What is the opinion of MCE timwilky Bikes - Talk & Issues 6 17-10-07 07:31 PM
valentines day : blokes opinion needed jenni Idle Banter 30 18-02-07 01:02 AM
