Old 01-05-12, 09:05 PM   #11
Dabteacake
Default Re: Exhaust extraction in the garage?
What about something like http://www.ebay.co.uk/itm/2-Metre-Ex...item43ab6d4109
Old 02-05-12, 09:29 AM   #12
muzikill
muzikill's Avatar
Exactly what I thought about doing it. Id fix it to the exhaust end using a metal band and the other end fixed to a vent. I dont know if I would need to add motorised extraction. Will exhaust fumes rise out to the vent. A small enclosed tabletop fan would be enough. Battery powered.
Old 02-05-12, 03:44 PM   #13
Could always wear...
But what YC said is the easiest
Old 02-05-12, 04:04 PM   #14
muzikill
muzikill's Avatar
rain, hail or shine!
After a good garage for exhaust mcgrimes Pennine Massive 52 14-09-10 07:23 AM
What's the minimum size for a garage to be a garage? the white rabbit Idle Banter 3 20-12-09 08:39 PM
Humour extraction Dicky Ticker The Essex Lounge 17 10-07-08 08:01 AM
garage anna South & West Surfers 4 04-04-06 03:29 PM
Your Garage! DanDare Idle Banter 45 20-01-06 08:02 AM
