Old 24-04-12, 12:25 PM   #11
mep
mep's Avatar
Default Re: Which chain lube?
+1 for a Scottoiler.
I used to have the touring reservor on my old GS500, but it wouldn't transfer to the SV with tail tidy so just the standard reservoir for now.
mep is offline   Reply With Quote
Old 24-04-12, 04:40 PM   #12
aliwakeskate
+1 for wurth dry chain lube. Works well and no splatters on the back wheel. Have been using it for 3 years now.
Old 24-04-12, 04:54 PM   #13
Geodude
Geodude's Avatar
+2 good stuff
Old 24-04-12, 07:05 PM   #14
alfa.rbt
I use a castrol one and can't say anything bad about it. However I have not tried any other so can't compare it. I'll be fitting scotoiler soon
Old 24-04-12, 07:29 PM   #15
aaron020873
I had a tutoro but took it off, I thought it was more trouble than it was worth
Sent from my GT-I9100 using Tapatalk 2
Old 24-04-12, 08:28 PM   #16
Badeye
I have a Tutoro oiler and it does the job spot on, just gotta remember to turn the bugger off hahaha - Defo worth the money
Old 25-04-12, 10:27 PM   #17
Lozzo
A bit of advice, if you're not getting the slightest bit of spatter from your chain lube, then rest assured it is not lubricating your chain. If it's not spattering it's just sitting there congealing and collecting road crap.
For this reason I avoid any kind of dry lube, chain waxes and anything that promises not spatter. For the last ten years my own bikes have had a Scottoiler fitted, except my trackbike which gets treated to Motul Road chain lube regularly. I find the Motul stuff is right at the balance of spatter and staying on the chain to do its job but Scottoilers are simply the best solution.
Old 26-04-12, 11:16 AM   #18
MJC-DEV
MJC-DEV's Avatar
Having had a Scotoiler for many years and the new Automatic Tutoro oiler, I personally prefer the new Auto Tuturo. I would say both are excellent in any case.
But with either, as Lozzo says, you wont believe how clean your chain will look with a 'total loss' system.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 26-04-12, 11:28 AM   #19
HoL
Nice to see Tutoro have done an automatic one now, at a good price too, thats what put me off getting one. I knew I'd never remember to switch it off!
Old 26-04-12, 01:02 PM   #20
MJC-DEV
MJC-DEV's Avatar
Photos here for those interested.
http://forums.sv650.org/showthread.php?t=175930&page=2
Chain Lube Flybuster Bikes - Talk & Issues 19 21-06-11 06:56 PM
Used oil for chain lube sunshine SV Talk, Tuning & Tweaking 26 27-09-09 09:39 PM
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Chain lube. furrybean Ancillaries 17 02-11-07 06:33 PM
Chain Lube fred_dillon SV Talk, Tuning & Tweaking 12 25-05-05 08:30 PM
