#11 | |
The second is to do with a file corruption with HomeGroup. Delete the 'idstore.sst' from "C:\Windows\ServiceProfiles\LocalService\AppData\R oaming\PeerNetworking" and then start the HomeGroup troubleshooter which recreates the idstore.sst on restart. Instructions for the troubleshooter are here http://windows.microsoft.com/en-us/w...troubleshooter |
#12 |
All Firewalls off (Windows+Router)
idstore.sst deleted, restored by troubleshooter. Problem not resolved ![]()
Formerly known as Gajjii Previous Bikes: Red Sk1 Curvy, Red MT-07. Current Bike: Black MT-09. |
#13 |
you've not named the computer/server the same as any of the other 2 have you?
can you get an internet connection? |
#14 | |
So, tell me a little about the pc. Its a 64 bit copy of Windows, connected up to your internal network etc yes? Are you able to browse the internet from this client? Can you ping its IP address from your other clients (when its client firewall is disabled)? |
#15 | ||
64bit Windows 7 - Yes Connected same internal network - Yes Browse Internet - Yes I'm using it now. Can Ping to and from MRS's , Ping the PS3 and the phone without problem. Homegroup works fine & network shares work as expected (PC's can see each other and share files).
#16 |
could you take a look in the 'network and sharing center' app and look for the network your computer is part of. Check that the network type is set to 'Home' rather than work or public.
#17 |
Yes set to Home.
#18 |
![]() ![]() ![]() May be coincidental but first noticed it working when having both Wife's account and my own both active at the same time. Other things that may have helped: Disabled numerous Services and start-up programs e.g. anything with Adobe or HP in it. System updates .Net framework has been updated but have no idea why or if its related. Anyway its working now, as is PMS which is a lot better. ![]()
calling all geeks(in the nicest name calling way) | jim@55 | Idle Banter | 11 | 25-06-07 08:55 AM |
Laptop guru required. | rictus01 | Idle Banter | 15 | 18-02-07 09:11 PM |
