Old 26-07-12, 01:20 PM   #11
Fallout
Fallout's Avatar
Default Re: Breaking in a new Engine - Mototune method
Originally Posted by Owenski View Post
Now just got to figure out how to do that on the commute ... either that or hit the lakes for a weekend
Easy mate. Start bike. Ride to layby. Stop. Wait for first fit girl in her little hatchback to drive by. Stonk it past her, showing off. Stop. Wait for her to pass. Stonk it past again. Repeat!
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 26-07-12, 01:46 PM   #12
It's the don't baby it bit that's important, if you ride it like it's got no water in it or something then it is likely to use oil and low compression.
Riding to work you should be able to get a decent range of rpms pulling out of junctions etc.
Though a decent day out should have it well broken in. Most of the important stuff happens in first few heat cycles, IMO.
Old 26-07-12, 01:46 PM   #13
or if you buy a new F3 it doesn't need run-in
http://www.ultimatemotorcycling.com/...cilities-video
http://youtu.be/cTCVRxCeFHk
YouTube Video
But the sid squid method works, that how I ran the 125 in
Old 26-07-12, 02:23 PM   #14
Owenski
NIce vid!
So none of this keep it below 5000rpm bullocks
Old 26-07-12, 02:24 PM   #15
dyzio
dyzio's Avatar
What are you buying?
Old 26-07-12, 03:43 PM   #16
Mark_h
Mark_h's Avatar
I read something on a scooter forum a while back (which I can't find now) that said piston linings had a sacrificial machined pattern on them that was designed to offer some abrasion to the piston rings and get a better fit. If you don't ride it reasonably hard in the first few miles (like on the way out of the showroom) then the pattern wore off before you got anything working hard enough to take advantage of the pattern.
They then produced various engines that had been run in hard v those run in gently and showed far better condition on the hard engines.
However :-
1) This was a scooter forum
2) The bloke may have been doing a roaring trade in new engines from yoofs who wheelied out of the local Chinese scooter showroom.
Minister for Sustainability
Old 26-07-12, 04:00 PM   #17
Owenski
However :-
Thats pretty much the mototune argument, my understanding been the hone pattern on the cylinder wears irregular. This allows for hot oil to leak past the rings and remain inside the combustion chamber, similarly it allows combustion to leak past the rings resulting in lower compression and lower power from the engine
~ I don't pretend to fully get it, that's just what i took from reading the article.
Sid and Chris seem to agree, riding it like a fanny will cause it more harm than making it work through the gears and rev range. Therefore if I do get a new bike this is the advice I'll be following.
Old 26-07-12, 04:16 PM   #18
NIce vid!
I'd that for about 100 miles on a YBR125, then started commuting on it up to flat out speeds
Old 26-07-12, 04:48 PM   #19
grimey121uk
I managed to do the magical 1000 miles on the GSR in 9 days, im not really convinced that it needed the full 1000 miles to break in fully as it seemed to loosen up just before the 600 mile service.
I just stayed on the twisties and b-roads for the first 600 miles and give it a bit of stick whilst keeping the revs below 6000ish. Between 600-1000 i pushed it a bit harder not really watching the revs but making sure I wasn't riding like I stole it / bouncing it off the limiter etc.
I think the business of running in is over complex with all these theories, the amount of time I would of spent researching the best method on the internet would of taken longer than racking up the 1000miles following Suzuki's advice.
Just take it out for a spin on some nice twisites and have some fun
Old 26-07-12, 04:54 PM   #20
AndyBrad
My personal opinion.. although it's different on bikes.
It doesn't matter that much. I've looked at the liners of very old cars and cars that have done good mileage and you can still see the honing patterns really well. On a bike I imagine it is similar but a lot of the liners have a hard wearing coating.
The issue with running in is to make sure everything is seated and running well as well as bedding in. Obviously ragging it from a freshly built state isn't going to help either. Nore is allowing it to labour.
Sent from my GT-I9300 using Tapatalk 2
Breaking GSXR 750 Engine K1-K3 twowheels For Sale - Other Bikes and General biking items 0 06-09-11 01:56 PM
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Breaking in your engine? LeeSV Bikes - Talk & Issues 4 09-02-08 12:09 AM
Breaking my old engine Stormspiel For Sale - SV's and SV related items 0 01-12-06 10:27 AM
engine breaking Shinsei Jutsu SV Talk, Tuning & Tweaking 7 23-01-05 06:30 AM
