Old 01-10-12, 02:58 PM   #11
Fallout
Fallout's Avatar
Default Re: Plastic screw point repair?
I have a few of them kicking around. No idea how to pop rivet though. Suppose I could weld a nut onto the back of it too ... if I knew how to weld.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 01-10-12, 06:21 PM   #12
Tomor
Tomor's Avatar
i have a pop rivet gun if you need to borrow one?
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 01-10-12, 07:39 PM   #13
mikerj
The simplest, non-destructive fixing I can think of would be a screw mountable cable tie
Old 01-10-12, 08:07 PM   #14
Spank86
I've got some fecking huge cable ties to give you if it'll help.
Old 01-10-12, 08:39 PM   #15
had a thought. you could heat up one of those metal L brackets then while still hot push it threw the plastic from the inside. when it cools it should melt the plastic to the bracket. ooohhh and i know what your like so use needle nose pliers or your going to get burny burny fingers
Old 01-10-12, 10:46 PM   #16
ThePone
ThePone's Avatar
How about a bit of fibreglass then drill a hole through it?
ThePone is offline   Reply With Quote
Old 02-10-12, 04:54 AM   #17
Mark_h
Mark_h's Avatar
I've got a rivet gun and tap/die sets if you want to come over and have a play. Araldite and a bit of exhaust strap or a bracket would be simplest.
Minister for Sustainability
Plastic number plate screw/nut yellow. krhall Stuff Wanted 4 03-08-09 07:17 PM
Screw for that little black plastic panel breakz187 Stuff Wanted 1 08-06-09 06:12 PM
help, plastic repair Kilted Ginger SV Talk, Tuning & Tweaking 3 09-08-08 03:53 PM
Plastic / Fairing Repair (Plastic Welding) Solution MattP SV Talk, Tuning & Tweaking 2 29-06-06 04:14 PM
Plastic repair and painting help SilverSV SV Talk, Tuning & Tweaking 2 02-08-05 04:50 PM
