#11 |
last change saloon for these.
#12 |
Cant believe no one wants these!!! never mind, back of the work shop these go until someone else crashes there bike then they cost over £250! Never mind
#13 |
I take it most sv's the colour these are in already have lowers !
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#14 |
Junior Member
Hi sniff, I've sent you a pm. Cheers, Ryan.
#15 |
hi mate what does the fitting kit include? i need the crash bung bracket that goes through the L/H lower side fairing?
#16 |
A photo would probably help a lot.
#17 |
Hi, are the fairings and the kit still for sale? If so what condition are they in?
#18 | ||
#19 |
I'm useless at using this forum! Who is selling the fairings? is it Sniff or Nobbylad? Are they still for sale and can I buy them please?
#20 |
Apologies - all I was pointing out was that the original thread said they were brand new. From your PM, I understand that they're sold, I don't have any for sale.
Lower fairings fitting kit for pointy | nerd | Stuff Wanted | 1 | 01-09-11 02:25 PM |
Pointy lower fairings fitting | shelleyamy | SV Talk, Tuning & Tweaking | 6 | 10-01-11 07:37 PM |
Lower fairings fitting kit | joshua02 | SV Talk, Tuning & Tweaking | 3 | 06-05-10 01:20 PM |
K4 Lower Fairings Fitting Kit | booner | Stuff Wanted | 0 | 27-07-07 03:31 PM |
Fitting lower fairings | bikerskez | SV Talk, Tuning & Tweaking | 8 | 24-12-04 10:51 PM |
