Old 25-06-13, 02:55 PM   #11
Default Re: Pointy won't start
what do you mean by 'adjusted clutch'?
Old 25-06-13, 02:57 PM   #12
mase_tw
Had this the other day turned out my alarm had killed off my battery! Get it charged or test the battery make sure it is fully charged... just a thought
Old 25-06-13, 03:25 PM   #13
PyroUK
PyroUK's Avatar
Default Pointy won't start
Followed Anna's clutch adjustment guide.
Worked a treat after, just knackered now lol
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 25-06-13, 03:33 PM   #14
well since the bike was working before hand then you have obviously disturbed something. so what does that tell you to do.
Old 25-06-13, 03:44 PM   #15
PyroUK
PyroUK's Avatar
Ask the motorcycle gods why it stopped working after riding home after adjusting it and before starting this morning!
And check the switch on the lever when I get home
Old 25-06-13, 04:20 PM   #16
PyroUK
PyroUK's Avatar
Well she starts!
Found the switch which I never knew was there. Turns out the lever doesn't even use it, the plunger is out and the bike starts. If I push the plunger in it doesn't so I think the wires may have been reversed or something.
Anyway thanks to all who said it would be the switch, feel like a complete knob!
Old 26-06-13, 09:15 PM   #17
Jason H
Jason H's Avatar
Originally Posted by PyroUK View Post
Well she starts!
The prong/plunger or whatever sits in a little slot on the lever.
If you're still having problems I can always have a look saturday or something.
J
Naked K5 - Now Red with sexy stripes!!
Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock
Jason H is offline   Reply With Quote
Old 26-06-13, 09:22 PM   #18
leebex
Or you have cack cheapo wobbly Chinese levers like mine, so sometimes they activate the switch sometimes they don't, when it doesn't I have to move the lever a notch.
Useless crap that I need to get removed. My clutch switch has been moved to the clutch actuator under the front sprocket cover for some reason too.
Old 27-06-13, 06:42 AM   #19
PyroUK
PyroUK's Avatar
Jason,
Think you have the same ones as me so would be good to see how yours work but I think it is a bit of a trek just for that, will see if the GM lot are planning anything.
Old 27-06-13, 11:28 AM   #20
Jason H
Jason H's Avatar
Yeah they are exactly the same as yours and not had a problem unless you adjust closer than about 4 I think.
If not it's a good excuse for me to go for long(ish) ride.
Pointy start up display? TheRuffellator SV Talk, Tuning & Tweaking 3 05-05-13 09:16 PM
Pointy won't start. DanSp SV Talk, Tuning & Tweaking 3 28-02-13 10:39 PM
Must be summer, Pointy wouldn't start. munkygunn182 SV Talk, Tuning & Tweaking 10 27-03-12 05:18 PM
Pointy won't start! trinyquist SV Talk, Tuning & Tweaking 19 15-10-08 10:35 PM
Please Help Pointy woes - won't start. RGV250ads SV Talk, Tuning & Tweaking 17 20-05-08 04:28 PM
