Old 01-08-13, 11:12 AM   #11
jambo
jambo's Avatar
Default Re: Front and Rear Sprocket sizes (Pointy 09) Fully Faired?
Originally Posted by nikon70 View Post
this is actually quite interesting, as I am getting pants mpg on the motorway at the moment, mind you I do pelt it up the m1
If I had the time and money I would swap the chain & sprok depending when I am going but that's just too much of a faf...
I might go up a few teeth on the rear and down one or two on the front when I change the chain....
good read
Up at the back, down at the front is lowering the gearing. So your fuel economy on the M1's unlikely to improve
A larger front and / or smaller rear raises gearing for lower RPM for a given road speed & gear combination.
at 15/45 as a baseline, the rear is 3x larger than the front, so 1 tooth up or down at the front is the same as a 3 tooth change at the rear.
Jambo
Old 01-08-13, 11:28 AM   #12
aesmith
Have a look at this web site, you can try different combinations and see the resulting speeds at different revs ...
Gearing Commander
I don't know if the absolute figures are correct as it predicts slightly higher speeds than I actually see, but it should help see how much difference a given change would make.
Sprocket sizes, Pointy S? granty92 SV Talk, Tuning & Tweaking 18 04-08-12 07:43 AM
K3 650 fully faired gsxr front end £1300 widget For Sale - SV's and SV related items 22 01-02-12 04:11 PM
sv650s fully faired k3 gsxr front end widget For Sale - SV's and SV related items 15 16-09-11 09:50 AM
Looking for fully faired pointy Maruchino Stuff Wanted 0 26-07-09 05:50 PM
