#11 |
You need to check your not stressing any connections.
Be careful very high deadly voltage from the ballast!
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#12 |
Guess ill have to take it all apart again tomorrow and make sure everything is comfy in the front fairing. If all is well - what else could it be?
#13 |
Could the fuse for low beam have blown? If so - what would the reason for that be? Is it easy to get to the fuse box?
#14 |
If it works when you tried it before fitting the fairings chances are its all Ok.
If you have a bad component your have to check low voltage connections first. Then it's substitution of the hi voltage parts. Unless you are super human
#15 |
I fitted the hids and held the front fairing up to the bike and plugged in the main connector. They worked. There was some flickering before I started the bike but once I started it, they worked. The left side acted as low beam and when I flicked on high beam they both came on. Then less than 10 mins later I started it again and only the high beam worked. If i have to switch to high voltage then it's getting the Eastern Beaver kit isn't it?
Sent using a device that allows me to coalesce my thoughts with radio frequency waves and transmit them over long distances. |
#16 |
If it worked once then didn't and nothing has changed apart from screwing in some bolts. The bike hates me.
#17 |
H4 =bi xenon. So you should have a thick 2 conductor to the bulbs from the ballasts . Then two thin ones that come from the control box (relays).
Then your old H4 connector has a connection to the control relays. Separate 12v feed via the control box to the ballast
#18 |
That is exactly what I have.
#19 |
Without a separate 12v feed.
#20 |
That's maybe why it's not working properly. See second diagram.
Your better of having a seprete fused supply to the ballasts.
Fitting an end can, how? Yet again. | Chris199 | SV Talk, Tuning & Tweaking | 12 | 22-06-12 10:12 PM |
Been fitting .... | Teejayexc | SV Talk, Tuning & Tweaking | 9 | 15-03-11 09:53 AM |
R&G Fitting | cb5_keith | SV Talk, Tuning & Tweaking | 14 | 25-06-08 11:53 AM |
DIY Can Fitting | Jackhammer | SV Talk, Tuning & Tweaking | 14 | 15-02-08 01:12 PM |
Fitting CCC | cuffy | SV Talk, Tuning & Tweaking | 57 | 27-01-06 09:36 PM |
