Old 18-07-15, 07:28 PM   #11
frazer1981
Default Re: bike cutting out, back firing and not restarting.
Could that be the problem ? And how could I test that ? Is it possiable to bypass it for a few days to see if it makes any difference? I know that may sound silly but need to get to the bottom of the problem ASAP.
Old 18-07-15, 11:17 PM   #12
embee
embee's Avatar
Originally Posted by TamSV View Post
Common rubbing points on the curvy loom are under the riders seat (securing bolt is slightly too long) and around the headstock. Also make sure battery terminals are clean and tight.
The other one is under the pillion seat inside the cubby box, at the rear on the nearside (rider's left hand side as you sit on the bike). The wiring harness curves round a frame bracket and can wear through.
Remember to check behind both rider's seat bolts too.
Firing On One Cylinder and Binding Back Brake. rivsm SV Talk, Tuning & Tweaking 12 20-04-13 09:45 AM
Back firing? Stimpy SV Talk, Tuning & Tweaking 2 05-05-10 08:00 PM
Back firing and fuel cut off above 6000RPM pomo737 SV Talk, Tuning & Tweaking 0 12-03-09 07:16 PM
To much back firing how do i solve it?? :S:S:S sv_rider1990 SV Talk, Tuning & Tweaking 9 26-04-08 03:49 PM
Back firing thegripper SV Talk, Tuning & Tweaking 16 04-12-05 07:24 PM
