Old 23-05-05, 05:05 PM   #11
Don't use anything with solvents in- ie WD40- apparently it can attack the cable lining. I used the old "engine oil in a bag" trick- get a plastic bag, put in some engine oil, attach it very tightly to the end of the cable, and squeeze gently. You can also push and pull the cable slightly as well to help the process.
Old 23-05-05, 05:11 PM   #12
embee
embee's Avatar
a lot of cables are nylon lined, and nylon absorbs oil (and moisture) to some extent.
I use Halfords aerosol "nylon&rubber lube", which I suspect is basically silicone oil, seems ideal.
£10 for a new clutch cable sounds a no-brainer to me.
Old 23-05-05, 05:19 PM   #13
Bikerz
it is a brand new cable tho!
Old 23-05-05, 09:51 PM   #14
embee
embee's Avatar
Originally Posted by Bikerz
my throttle seems to be a bit sticky (the gd way of corse, full open ) tho i would like it to return properly, what u recomend i do to it? what shall i use on it?
have you had the airbox off and cleaned/lubed the carb end of things? It does tend to get a bit cruddy in there sometimes
Stiff throttle ArtyLady SV Talk, Tuning & Tweaking 18 27-06-13 11:26 PM
clutch and throttle cable joronsen SV Talk, Tuning & Tweaking 3 14-02-08 09:08 AM
Sore wrist cos the throttle seems really stiff...? 5v5 rider SV Talk, Tuning & Tweaking 1 04-07-06 05:16 PM
Clutch lever is very stiff The Mass SV Talk, Tuning & Tweaking 2 08-06-06 12:48 PM
Clutch suddenly stiff leatherpatches SV Talk, Tuning & Tweaking 5 09-03-05 10:30 PM
