#11 |
so if H G dont do a filter for the k3 what do you do at service time? not bother changing it or buy one from somewhere else?
#12 | |
#13 | ||
#14 | |||
#15 |
i just do very basic maintenance im afraid and have never delved into performance criteria but have been reading some threads with interest. mine is pretty bog standard at the mo. just a ccc fitted.
![]() earlier thread remember someone saying there machine was setup like mine and running lean, stuttering etc but never had any probs so far that i can honestly tell. smooth n fast ![]() just out of interest, local car and body shop sell a high performance oil additive as used in race engines of all sorts. it leaves internal parts lubricated, has anyone used anything like this. stops knocking, excessive wear etc ![]() |
#16 |
cloggsy! would my k3 run ok with a K&N filter on and my scorpion can without a remap?
#17 | |
These aftermarket additives will always be advertised as being the best thing since sliced bread, used by all the race teams (yeah, right), what else would you expect? Contrary to popular belief, most major oil companies actually know what they are doing. |
#18 |
Hi
I notice from another post where the poor sod has to fork out a lot of money to repair their gearbox that the gear teeth are straight cut. This means that the pressure of the drive from meshing gears is spread over the entire width of the tooth. This means the oil has less work to do to keep the teeth seperated compared to a conventional manual car gearbox, where the gears are helical cut. Helical cut gears are quieter, but the drawback is that the contact point is much smaller. This means the oil must withstand extreme pressure. This is what the EP stands for in EP80 or EP90 for car gearbox oil. My guess is that this is why bikes can use engine oil for the gearbox as well as the engine. Do bike gearboxes have syncro-hubs like car gearboxes? If they do, the oil used is also an important consideration. The cones in the syncro hubs must be able to shear through the oil to syncronise the speed of the hub of the gear you wish to change to. If the oil has too high a shear rating it will make it more difficult to change gear. Kind regards Tim |
#19 |
Bike gearboxes are the constant mesh type.
#20 | |
Kind regards Tim |
Engine Breaking? Hopefully not. Engine braking - is that OK? | butterick99 | SV Talk, Tuning & Tweaking | 14 | 12-09-09 10:31 PM |
Ever worry about having too little oil in your engine? No, I check it every now and again. | SoulKiss | Bikes - Talk & Issues | 12 | 22-07-08 09:19 AM |
Engine braking... any hazzards engine wise? | John 675 | SV Talk, Tuning & Tweaking | 21 | 28-03-08 07:20 PM |
check out my tat | yellowsvracer | Idle Banter | 19 | 31-03-07 05:14 PM |
Oil or Check engine light is on | wilsonma08 | SV Talk, Tuning & Tweaking | 0 | 16-08-05 06:00 AM |
