Old 10-10-06, 09:02 AM   #11
wyrdness
As other people have said, it depends on the road and the conditions. There's no single correct answer here.
Coming home from work, I turn into my road off a main road at over 20mph (if it's dry and there's no hazards). If conditions are really good, then I'll just use a bit of engine braking and turn even faster, though this is rare.
Old 10-10-06, 12:16 PM   #12
Caddy2000
If you can see far enough so that you can stop in your lane then the speed is acceptable. It all depends on the observed and perceived risks (diesel, loose road surface, pedestrians, tyre temp, etc, etc, etc).
If it's all clear, empty, and you can stay in the right lane then why not? If you can't do any of the above then no; it's too fast!!!
Speed doesn't kill! - People kill!
Aren't echo's of other people's thoughts a good thing?
Old 10-10-06, 12:19 PM   #13
Mogs
As I agree with all the above - I've not much to add, so Hello.
Debate at work.. Sean_C Idle Banter 30 10-09-08 01:10 PM
garage debate of the day dizzyblonde Idle Banter 26 11-04-08 10:27 AM
The Trident Debate DanDare Idle Banter 73 05-12-06 05:48 PM
Let's have a heated debate! philipMac Idle Banter 20 29-04-06 01:54 PM
Todays hot debate Viney Idle Banter 36 28-04-05 01:49 PM
