Old 28-02-10, 01:01 PM   #271
Default Re: rear shock change
Older one has clevis on top with big (20mm ish) thread, but this is how it mounts and you add washers to increase height.
This doesn't work on SV 'cos the clevis is part of the frame.
Old 28-02-10, 01:10 PM   #272
-Ralph-
I have the clevis, as the thread is sticking out of the top of the cling film, but obviously I won't be using it.
Old 28-02-10, 05:20 PM   #273
TheShadow
Lucas,
How do you find that shock? i have a similer one in my curvy but find that its very soft , when i sit on the bike the ride height drops a fair bit even with full preload.
If yours is fine with the stock spring somethin must be wrong with mine as i am a light chap.
Old 28-02-10, 09:28 PM   #274
Lucas
Originally Posted by TheShadow View Post
Lucas,
only covered about 50miles on it so far, but compared to the ten year old shock, the zx10 shock is a 100% improvment. I can feel the tyre & road interaction better, while bumps are smoothed out and I don't bounce any more
i'm 11st and the shock feels fine at the moment, sitting on bike it sinks the same amount as my old shock. haven't done fast-fast rides on it yet so not idea how the current setting will do...
anyway, these are the settings:
preload = 179mm (spring end to end length)
low speed compression = 1 turn from full clockwise
high speed compression = 2 3/4 turn from full clockwise
rebound = 2 turns out from full clockwise
will be playing around with these settings over the next months
HTH
Old 01-03-10, 09:26 AM   #275
Taipan
Taipan's Avatar
Originally Posted by Lucas View Post
here are the pics of a 08 ZX10R in a curvy
Excellent. Thanks for those.
Old 01-03-10, 05:50 PM   #276
TheShadow
When trying to get the shock to feel good i only changed the screw adjusters. Compression and rebound. I take it the other adjuster is the bolt shaped one what does this do?
Old 01-03-10, 06:13 PM   #277
Bolt shaped one near reservoir around the outside of comp. adjuster screw is highspeed compression adjuster.
Old 01-03-10, 09:59 PM   #278
Liam9188
Fitted my zx10r rear shock to my curvy today. a short test ride proved it to be a massive improvement, giving a better ride and much more confidence accelerating over bumpy tarmac. Can't wait to play around with the settings and really get it working nicely. Which screw is which?
Old 01-03-10, 10:00 PM   #279
One at top is comp.
One at bottom is rebound.
Old 01-03-10, 10:01 PM   #280
-Ralph-
One at top is comp.
Come on then, what should I set them at? Save me googling for a manual!
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
