Old 12-07-08, 06:49 PM   #21
Default Re: Serious Gearbox problem :(
Right then time to inspect the external shift mech.
What is it doing in second which is different to the rest of the gears, possibly one of the dowels is bent and it's needing pushing down before it's dropping into the notch properly.
Old 12-07-08, 07:34 PM   #22
silent11
hi m8
basically it seems it doesn't "reset" itself, so ive made a vid for you to see (sorry about quality)
it shows me selecting 1st then 2nd and you will notice at 57,56 seconds to go i lightly pull on the lever and it "resets" again, then onto 3rd,4,5,6
http://s35.photobucket.com/albums/d1...t=MOV00266.flv
sorry if i explain crudly not a true expert
thanks allot for your help
phil
Old 12-07-08, 07:47 PM   #23
You don't need to be so rough with it for a start! If it doesn't want to select a gear when it's trying to move stuff then just slowly move the wheel while maintaining pressure on the lever, it'll drop in smooth as owt then.
Anyway, not resetting in second seems to indicate the problem is external, which is good news.
Need to go and look at an engine... back in a bit!
Old 12-07-08, 07:53 PM   #24
I'm thinking the shift detent cam, have a gander at it and see if any of the pins look bent or chipped.
Old 12-07-08, 08:09 PM   #25
silent11
right just had a look, and ive found it
cam shift plate is broken, its basically got a piece taken out of it at the top. doesn't look like a bottle opener now lol
so that seems to be the problem, would o noticed it earlier but i thought that was how it was
now where can i get one of them from?? and do i need to take the clutch assembly completely off, if so i will do that while finding a cam shaft plate
thanks again for your help yorkie
Old 12-07-08, 08:16 PM   #26
I've got one. make me an offer
Old 12-07-08, 08:28 PM   #27
silent11
do you mind if i can have a picture of it
mainly cause ive just seen the parts chart http://alpha-sports.com/spst/2006%20SV650S/32.gif
figure 19
and that is split in the middle to, is this right? as thats how mine looks
Old 12-07-08, 08:37 PM   #28
The one I'm looking at is complete like a bottle opener, pics to follow.
Old 12-07-08, 08:39 PM   #29
silent11
hmmm this is confusing
i looked on that abba site on the 2003 and 2004, they look like a bottle opener. but 05> they have a split in
Old 12-07-08, 08:46 PM   #30
Not impossible that they'd change over the years, but thinking about it that plate would affect all gears. I still reckon it's the shift star/detent cam which is at fault.
Gearbox Richie Stuff Wanted 0 09-07-07 08:09 PM
Gearbox Fix? seandixie SV Talk, Tuning & Tweaking 11 29-06-07 09:32 AM
Gearbox problem??? shortie SV Talk, Tuning & Tweaking 1 14-05-06 02:20 PM
Gearbox Daglad SV Talk, Tuning & Tweaking 12 02-04-06 09:26 PM
Gearbox sprocket. cassius SV Talk, Tuning & Tweaking 6 02-02-05 11:33 PM
