Old 26-05-09, 02:36 PM   #21
Zen Beetle
Default Re: GI pro gear indicator
There are cheaper alternatives (acumen) but they don't work directly off the CPU and are therefore not as accurate. They also need programming, while the beauty of the GiPro is that it simply plugs into the dealer mode socket under the seat. I know its expensive and an extravagance but it is a birthday present after all.
Old 26-05-09, 02:41 PM   #22
Dave20046
Dave20046's Avatar
dealer mode socket have I stolled into pointy talk?
Think my birthday present to my self will be either a camera set up or a trackday I'll put one on the wish list though, what's battery drain like?
Old 26-05-09, 02:50 PM   #23
SoulKiss
SoulKiss's Avatar
Anyone know which pins and the encoding that this thing uses to read the current gear ?
Shouldnt take brain surgery to put something like this together
Old 26-05-09, 02:59 PM   #24
ophic
ophic's Avatar
yeah i looked at doing one - seems entirely possible. The gear position sensor provides a different resistance for each gear - the values are listed in the workshop manual.
Silver SV650SK3, Fuel exhaust
Old 26-05-09, 03:04 PM   #25
SoulKiss
SoulKiss's Avatar
Hmm and as I know of a certain programmable microcontroller that can read input resistance and then output to a 7-segment display...........
Old 26-05-09, 03:06 PM   #26
ophic
ophic's Avatar
Old 26-05-09, 03:08 PM   #27
SoulKiss
SoulKiss's Avatar
Originally Posted by ophic View Post
Maybe add a MP3 decoder, an amp and a speaker then sample Top Gear so that wne it gets into 6th I can have Clarkson yell "POWER!!"
Or maybe not
Old 26-05-09, 04:26 PM   #28
stevebetts
Originally Posted by Zen Beetle View Post
. The issue of whether bikes should be greener and its ethical implications is best left for another thread. Besides, I don't want to bore you to death.
too late.........
Old 26-05-09, 04:43 PM   #29
Zen Beetle
+1 Steve. I suppose I had it coming.
Old 26-05-09, 05:07 PM   #30
hob
Originally Posted by Stu View Post
Interested to know about the set up though Hob? as I didn't have to go through it. Although mine is an Acu...? not GI, but it looks the same. so you say it learns it, but got it wrong first time how do you teach it? I don't seem to have any input.
The GI thought each gear was higher than it was, (i.e that magic 7th gear), it didn't like the down for first then up for second, it knew each gear was separate but missed gear 2, I had to push a button (hold it for 5 seconds or something) and it would cycle from gear 1 to 6 and you would change gear to suit, once it had recalibrated the gears it was spot on
gear indicator auldyin SV Talk, Tuning & Tweaking 1 12-07-06 09:52 PM
Gear Indicator PWNDLOL SV Talk, Tuning & Tweaking 5 22-05-06 05:03 AM
Digital Gear Indicator Thaleshwar SV Talk, Tuning & Tweaking 33 04-04-06 06:54 AM
Gear indicator Banus SV Talk, Tuning & Tweaking 0 16-03-05 01:38 PM
DIY Gear Indicator. Chinaman SV Talk, Tuning & Tweaking 16 14-12-04 10:18 AM
