Old 21-11-09, 06:03 PM   #21
Biker Biggles
Biker Biggles's Avatar
Default Re: Clunking noise
Have you checked the front sprocket nut is not coming loose?As for the clutch do a search here for clutch adjustment and do all that it says.
Old 21-11-09, 07:55 PM   #22
Grant66
Grant66's Avatar
If you wanna have a look, the clutch cover is only a rubber oring
Which relies on knowing what it is I'm looking at.
could you of worn your clutch out?
or maybe clutch springs gone?
Don't think so, unless clutches wear out overnight It was all working Thursday, apart for a clunking noise. Between it working and not working I messed about with the chain and cleaned cr*p out around the clutch adjustment thingy. so I'm thinking it must be related to the clutch adjustment somehow.
Haven't but will in the morning. The haynes manual isn't as good as the "Anna Method", I'll make sure this is done properly in the morning.
Thanks for the help, I'll let you know how I get on.
Grant66 is offline   Reply With Quote
Old 22-11-09, 12:53 PM   #23
Grant66
Grant66's Avatar
Its not gone too well. Sprocket checked and tight. Clutch cable adjustment performed. No change, clutch engaged and operation of lever does not dis-engage.
Lever pulled left, lever not pulled right.
Does this look ok? If so any thoughts as to what else to check/fix/adjust?
Is it rotating enough? Is it moving the push rod far enough or is the problem at the other end of the push rod?
Is it possible, bouncy chain (see earlier) has bent the push rod? ergo its not pushing enough?
Old 24-11-09, 04:01 PM   #24
Grant66
Grant66's Avatar
Default Re: Clunking noise -Fixed
All working again, thanks to Davepreston
Rear axle greased, bearings checked and assembled right way round, chain tension adjusted correctly, idle speed adjusted and thats before we got to the clutch.
Clutch adjusted properly and then he even adjusted the handlebar lever positions for me
All for the price of cups of tea and choccy biccies. Chears mate your a star.
And thanks to YC for the advice.
Old 24-11-09, 04:59 PM   #25
beabert
Good man
Old 24-11-09, 05:55 PM   #26
davepreston
dont forget the mutterd thanks to the small green one (i knew it so why do i have to check with him still ,git)
total mechanical amateur - Clunking noise when accelerating? Any Ideas TechJinx SV Talk, Tuning & Tweaking 10 23-06-09 01:27 PM
It still makes that clunking fork noise. Tony_BLY SV Talk, Tuning & Tweaking 29 01-03-09 10:48 AM
clunking noise under braking nik_nunez SV Talk, Tuning & Tweaking 24 28-08-08 04:24 AM
Clunking noise on GSXR750 rubberduckofdeath Bikes - Talk & Issues 8 06-06-08 05:19 PM
clunking chain noise steveg Bikes - Talk & Issues 4 23-03-08 10:39 PM
