#21 |
they also did what i think he meant was my suspension the 2 screw like things on the top yoke, but not felt the difference yet came straight home from the garage due to weather..
#22 |
I should have watched what he did with the gear lever, im still none the wiser..
#23 |
There isn't much to it. As soon as you will take a closer look at it you will figure it out. There isn't anything you could do wrong (other than forgetting to tighten the nuts
#24 |
I like to have my gear lever low down, also when adjusting it pays to pay attention as i managed to put mine on the wrong way and ended up with race shifting
#25 |
think i might need to buy a tool kit, is there like a basic amount of tools im going to need....?
#26 |
Sorry to be such a noob. Can anyone point out or explain more clearly how to adjust the gear lever as I've just had a look and can't figure it out
![]() Help! |
#27 |
I have the same problem with changing gear, but I think the root cause is the size of my feet vs the length of the gearlever. When my foot in the natural/comfortable position on the peg the end of the gearlever is way up my foot towards my leg and my boots/feet are very thick at this point so I have to make a really exaggerated movement to move my foot above or below the lever which is very uncomfortable. It's also very easy not to quite fully remove my foot after a change (due to the discomfort of angling my foot so far up/down) which means the next change doesn't work.
Adjusting the gear lever position has definitely helped a bit, but a gear lever which is a good inch or so longer would be perfect. Is there anything from another bike I could adapt? |
Gear Selection Lever and Clutch Lever for K3 SV650S | xXBADGERXx | Stuff Wanted | 7 | 17-01-09 02:04 PM |
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) | martin_SV | SV Talk, Tuning & Tweaking | 10 | 30-07-08 08:40 PM |
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. | Bayside GTR | Stuff Wanted | 0 | 29-10-07 11:24 PM |
2 left indicators + clutch lever + gear lever for pointy k6 | enduroman | Stuff Wanted | 3 | 06-09-07 09:26 PM |
Gear lever as rear brake lever? | plowsie | SV Talk, Tuning & Tweaking | 2 | 29-05-07 05:23 PM |
