Old 16-03-11, 04:39 PM   #21
Default Re: check, no start, meta alarm, cant dealer mode
have you tried putting the bike in dealer mode using the plug under between the rider and passenger seat?
note to ones self read the threads properly lol
have you tried the 3 plugs at the front of the airbox?
Old 16-03-11, 05:27 PM   #22
davepreston
that will be this evenings task, need it all sorted by 31st march for mot, then i can become a biker again instead of what feels like a bike collector
Old 16-03-11, 05:30 PM   #23
i know how you feel fella. i'm sick of looking at parts and just want to ride the bleedin thing.
Old 16-03-11, 06:57 PM   #24
Girth
You checked the battery?
Alarms put an horrendous drain on the battery, when the battery drops the internal battery on the alarm starts to flatten and normally puts the alarm into panick mode IE shouts its tits off!
Worth checking the battery is alright.
Old 16-03-11, 08:21 PM   #25
davepreston
had it on charge while trying it still came up with the check message
Old 16-03-11, 09:01 PM   #26
tonyt
Have you checked the Tip over switch.. it can come off it's mounting..
Old 16-03-11, 10:24 PM   #27
davepreston
tos seems fine
next
Old 16-03-11, 10:31 PM   #28
monkey
Has someone got an ECU you could swap over to try?
Old 16-03-11, 11:13 PM   #29
flymo
flymo's Avatar
I would go for;
dodgy battery - hook some jump leads up to something decent, car batter if you have one.
broken switch or connector somewhere - I know you've checked this stuff but check for possible crash damage that might cause this.
fuses? - have you checked them all?
alarm system itself - was it working ok before? sounds like the immobiliser is still active preventing it from firing, usually its the ignition system that is used for alarm immobiliser function
was it a runner when you got it?
Old 16-03-11, 11:55 PM   #30
davepreston
battery as run from house charger straight onyo bike
fues conections i will check again
alarm was grand before crash
yeah its beenies old bike i bought it the week after the crash
Meta alarm Icanopit Bikes - Talk & Issues 6 10-11-09 11:29 PM
How do you put the bike in dealer fault mode? rowdy SV Talk, Tuning & Tweaking 7 31-01-09 09:07 AM
META Alarm....HELP with immobiliser! thepyrofish SV Talk, Tuning & Tweaking 12 01-04-06 06:54 PM
Meta Alarm Help!!! Samurai Bikes - Talk & Issues 5 09-02-06 02:52 PM
meta alarm pagers Dimax3 SV Talk, Tuning & Tweaking 6 04-01-70 07:20 PM
