#21 |
Internal or external?
All I've got is the compressor and horn
#22 |
The Ebay one (GSXR?) was just the horn and went for about £4 less than a new one including a bolt and external relay. You should use a relay as the Stebel takes 18A vs about 4A standard going from the datasheet.
Just waiting for a Stebel look-a-like (Wolo) to arrive and planning to mount it on left hand Engine mount pinch bolt (Pointy) as I don't want to split it. Looks like some rubber anti-vibration mounts needed from what YC says. I have heard that they don't take well to vibration but will give it a go as nowhere much else to put it as a complete unit. |
#23 |
Don't tell anyone, but spent a few days post GM at Applecross with a former .orger. What with his Nautilus & my backfires could we have caused this > >
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#24 | |
#25 |
Yep, be interesting to see how long the look-a-like lasts as the genuine ones don't have a great rep for long life (and I don't even need the relay for my £29,
![]() Could well be the way it's mounted and vibration etc. |
#26 |
![]() ![]() Looks like £55 spent Vehicle Wiring products just buying odds and sod
#27 |
VWP is the devil, spend 30p here and there and the next minute it's £100!!!
The horn should be fine wherever if supported or on some sort of anti vibration mount. Andrew AFAIK any relays are external, the horns simply have a compressor motor with +ve and -ve terminals, mount relay wherever suits.
#28 |
Just a thought, Chris:
Is there a frame tube that could be pressurised & then use that to blow the horn? Eliminate electrics altogether.
#29 |
Interesting idea but you'd still need a switch and solenoid... Unless you want a 1/4 turn ball valve on the handlebar!
#30 |
Heres my set-up
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
Stebel Magnum fitting questions. | daveyrach | SV Talk, Tuning & Tweaking | 14 | 17-05-11 09:02 AM |
Hiding a Stebel Nautilus on a Curvy | maviczap | SV Talk, Tuning & Tweaking | 0 | 21-02-09 11:35 AM |
Stebel Nautilus on naked...fitting help | 600+ | SV Talk, Tuning & Tweaking | 15 | 15-05-07 09:47 AM |
Stebel Magum Fitting on a Pointy. | danf1234 | SV Talk, Tuning & Tweaking | 26 | 04-05-07 04:44 PM |
Stebel Magnum horn - fitting | Tigerrrr....... | SV Talk, Tuning & Tweaking | 3 | 23-09-06 09:45 PM |
