Old 07-09-12, 10:24 AM   #21
speedyandypandy
Default Re: Brake failure?
Originally Posted by monkey View Post
Must be a leak so slight it doesn't let fluid out but air in.
could be, to feel the difference after just 2-3 laps it would have to be many small leaks. A light brainstorm while painting woodenmouldings in our hall gave me some more ideas: maybe there is a small suction action going on inside the mc either when pumping or on return, so when hydrostatic pressure is equall there is no leak, but if there is "under" pressure it sucks in air if there was a hole/weak area somewhere. Could well be there was something wrong in the rubber form process for just that part and that it ended up "raw" or poorer quality than it should, maybe the guy should have sent it away to have it tested, but he just fixed it so he could go have fun again the following week.
MOT Failure JimmP SV Talk, Tuning & Tweaking 42 01-06-12 10:55 PM
MOT Failure? krhall Idle Banter 12 22-07-11 07:43 AM
MOT Failure melody Idle Banter 33 24-02-09 03:06 PM
Failure Dicky Ticker The Essex Lounge 14 30-10-08 08:52 PM
What a con! – MOT failure Blue_SV650S Idle Banter 30 25-05-07 07:11 PM
