Old 31-01-06, 11:04 AM   #21
mysteryjimbo
Originally Posted by TSM
When i was in collage about 7 years ago now, they did teach assembly basics on a Zilog Z80 proc. The teacher was sooo boring. But i liked it, just did not have a unit of my own to play with. I much prefered the teacher that did Pascal. Still i not good at either. Now im better in the modern languages.
I got pretty good at Turbo Pascal and assembler in college but now moved away from programming and into DB's.
Old 31-01-06, 11:45 AM   #22
tricky
I was using these (Aim 65) in 1986 and I'm guessing they where probably obselete then.
I once got one to play "Layla" by connecting an amp and a speaker up to it, and varying the frequency on two pins of the serial port (or somthing like that, it was 20 years and about 1200 gallons of beer ago)
I quite liked programming in assember, 68k mainly as I was quite good at that and absoulute crat at progaramming in everything else.
I do a bit of ksh scripting now which I'm not bad at, if you can count that as programming.
Old 31-01-06, 12:04 PM   #23
Skip
Skip's Avatar
To someone who uses other peoples ksh scripts (me!) - yes it is programming as I couldnt do it!!
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 31-01-06, 12:13 PM   #24
tricky
***********************GEEK ALERT***********************************
I wrote this in the hope it would be the last one I ever wrote.
I've removed the comments, see if you can work out what it does.
#!/usr/bin/ksh
main () {
for ball in 1 2 3 4 5 6
do
generate
numbers[$ball]=$num
done
generate () {
num=`echo $RANDOM | cut -c 2,3`
check
if [ $num -eq 0 -o $num -gt 49 ]
then
generate
fi
check () {
echo ${numbers[*]} | grep $num >> /dev/null 2>&1
rc=$?
if [ $rc -eq 0 ]
then
generate
fi
sortball () {
count=1
while [ $count -le 6 ]
do
for pos in 1 2 3 4 5
do
((nextpos=$pos+1))
if [ ${numbers[$pos]} -gt ${numbers[$nextpos]} ]
then
numbers[7]=${numbers[$pos]}
numbers[$pos]=${numbers[$nextpos]}
numbers[$nextpos]=${numbers[7]}
fi
done
((count=$count+1))
done
display () {
do
echo "Ball $ball = ${numbers[$ball]}"
done
clear
main
sortball
display
Old 31-01-06, 12:15 PM   #25
Skip
Skip's Avatar
Very good!
I take it that it hasnt been the last one you ever wrote??!
Oh and in case anyone is wondering - its a Lottery Number Generator
'81 Honda H100A
Old 31-01-06, 12:19 PM   #26
sharriso74
I was going to say bingo
Old 31-01-06, 12:20 PM   #27
TSM
The Sick Man
TSM's Avatar
Quite a simple prog realy. Not as if i could write it in KSH, i would do it in ASP.
Old 31-01-06, 02:27 PM   #28
I've got a rubber keyed Speccy and a Vic 20 somewhere...
Old 31-01-06, 04:02 PM   #29
tricky
I had a rubber keyed Speccy 48, those where the days.
Jet Pac, Manic Miner, Trans Am, Attic Attack etc
Old 31-01-06, 04:04 PM   #30
DanDare
Who had one of these then???????
http://www.inthe80s.com/toys/bigtrak.shtml
First fall - and on a lesson nik_nunez Bikes - Talk & Issues 13 08-07-08 08:59 AM
teaching them a lesson Wideboy Bikes - Talk & Issues 9 08-09-07 08:49 PM
Another day, another lesson veraliar SV Talk, Tuning & Tweaking 0 02-07-07 10:55 PM
History lesson cuffy Idle Banter 2 10-03-06 12:17 PM
History lesson part one Stingo Idle Banter 4 23-02-06 01:04 PM
