Old 11-09-07, 02:08 PM   #21
Ceri JC
Default Re: Bike Failed MOT
I would be interested as to what was causing it/the fix as one of my indicators on my K4 is doing the same thing. My headlights, touch wood, are fine. Mine thankfully only started playing up after the MOT.
Old 11-09-07, 02:11 PM   #22
hovis
[QUOTE=neio79;1284328]
. I spoke to the receptionist so she could not go into too much detail for lack of knowledge i suppose.
the flashy things are working sir?
Old 11-09-07, 07:01 PM   #23
neio79
Ill put it on here when i have been briefed tommorow by the 'technitian' ( i suppose that is the name for mechanics now?)
[quote=hovis;1284359]
basically yes
Old 12-09-07, 06:35 PM   #24
neio79
Well it turns out it was a problem in the indicator wiring. Bad connection or something.
Probably caused from the aftermarket mini indicators being stuck on it.
Its sorted, but i feel a bit miffed that i paid 125 for the privilage of it.
Old 12-09-07, 06:43 PM   #25
Stu
Trinity
Stu's Avatar
He he, its because we dont try to screw each other all the time up here
Don't worry, one day you'll find the love of a good women and all that will change.
Old 12-09-07, 06:50 PM   #26
Stu
Trinity
Stu's Avatar
Funniest thread ever, sorry it's at your expense (no pun intended) £125 for after market indicators - the price of fashion eh?
Old 12-09-07, 10:31 PM   #27
monkey
I'd have wiggled some wires for ya for half that!
Tell you one to watch out for-the front brake switch can fur up and stop working. Little squirt of WD and it's fixed.
Old 13-09-07, 08:08 AM   #28
neio79
Yeah , i bet they were laughing as well. I bet all they done was disconnect them and re wire back in properly. It was only so expensive because of the labour costs.
But im rich i can afford it!! LOL
dosent stop it being annoying though.
I was also takling to them about the suspension as well.
JHS dont recommend the GSXR shock upgrade apparantly its not made to withstand the heat of the exhaust running next to it. They will fit it but they dont recomend it. They said if you want to do it on a budget and replace it with an other bikes shock then the SV1000 is a good enough replacement. as its stronger has more adjustment and is built to with stand the heat of the exhaust pipes.
Old 13-09-07, 12:16 PM   #29
2mths
IMHO...
"Technician" sounds a bit better than "Fitter". It may or may not have any legal basis (in fact I doubt it) but when at college there was a discussion about the move away from calling people mechanics. The outcome of that discussion was half that it was insulting to 'real' mechanics to call somone who has little knowledge past changing oil & filter a mechanic and half that because they aren't. In the past (talking cars here a bit) things were adjusted and potentially checked for tolerance. Now that's rather rare (I can only think of valve clearances that actually get checked). Back to the legal bit I wonder if it's a phrase that sounds 'good' that can be used to refer to anyone who get's their hands dirty.
Old 13-09-07, 12:53 PM   #30
monkey
......JHS dont recommend the GSXR shock upgrade apparantly its not made to withstand the heat of the exhaust running next to it......
I've spotted their deliberate mistake-the exhaust is nowhere near the shock! Do I win a prize?
failed again shiver85 Bikes - Talk & Issues 5 17-05-08 12:04 PM
TRE mod failed on 07 vegacr250 SV Talk, Tuning & Tweaking 21 09-07-07 10:28 PM
Failed Test :( Abyss Bikes - Talk & Issues 76 27-06-06 05:48 PM
MOT failed Grinch SV Talk, Tuning & Tweaking 8 26-06-06 06:32 PM
dam failed my test didge Bikes - Talk & Issues 16 13-07-05 09:52 AM
