Old 18-05-09, 10:46 PM   #31
jamesterror
jamesterror's Avatar
Default Re: Never had a big bike
Originally Posted by Thingus View Post
I'd say 2.6 is nice for an 07 model O.O
____---__---__-_--__
Anyway man up (jk), 6 foot 2... you'll be fine on the SV. Keep weight forward ie, don't lean back and you'll be fine.
To be honest if i'd found this place before i found a dealer, i would've bought privately from here, not a dealer, but you get the warranty and things so good luck whatever you do.
I saw an 07 with 4k miles for £3100 in a local dealer, remus slip on can only mod
jamesterror is offline   Reply With Quote
Old 18-05-09, 10:57 PM   #32
Thingus
I'm not gonna bring up the price i paid for my standard (bar Scorpion can) 2000 W Curvy S.
Old 19-05-09, 07:57 AM   #33
plowsie
Also Hindle, general consensus is that modifications will not add to the price of a bike. So don't get caught with that mate.
Old 19-05-09, 01:10 PM   #34
hindle8907
hindle8907's Avatar
hi guys how do i tell which is a carbed version ?
i have been told this is the one to go for if resticted ? is this True ?
Old 19-05-09, 01:17 PM   #35
fizzwheel
fizzwheel's Avatar
Nice and simple, if the Bike was manufactured between 1999 - 2002 it will be on Carbs, the orginal first generation "curvey" shaped SV is carbs.
Any bike manufacturered after 2003 will be fuel injection. The 2nd generation SV with "pointy" plastics, and the twin LED rear brake lights is FI.
IMHO No its not.
Carb bikes restrict OK, as do the later style Fuel Injection bikes also restrict OK, but you would be wise to go down the ECU restriction route ( swapping the bikes electronic brain ) rather than the F.I. Internationl mechanical restriction route on a 2003 onwards bike.
HTH
Old 19-05-09, 01:20 PM   #36
ophic
ophic's Avatar
they look different. Anything K3 onwards is a pointy, and these are injected. Anything previous is a curvy, and these are carbed. The biggest difference is the frame - curvies have round tubed frames and pointies have squarish cast box-section frames (is that description right?)
Pointies are best restricted by changing the ECU. There's another method (FI restriction kit) but its not very good, by all accounts.
Curvies are restricted in the normal way for carbed bikes - washers in the carbs, restricting the air flow. This is apparently fine.
So both bikes can be restricted easily - i'd say the pointy is easier to do, but the cost of the restricted ECU might be greater than the kit for a curvy.
Edit: fizz beat me... again
Silver SV650SK3, Fuel exhaust
Last edited by ophic; 19-05-09 at 01:21 PM. Reason: need to type faster than fizz...
Old 19-05-09, 01:22 PM   #37
hindle8907
hindle8907's Avatar
2006 06 Reg SUZUKI SV SK6 650cc
http://search.autotrader.co.uk/es-uk...leRegLetter=06
So the above is a IF SV ?
Link above
Old 19-05-09, 01:27 PM   #38
ophic
ophic's Avatar
It's a pointy, so injected.
Old 19-05-09, 01:31 PM   #39
hindle8907
hindle8907's Avatar
when i went to view this i asked the Shop whats involved in resticting the Bike and he said they put washers in the carb ?? :S
Old 19-05-09, 01:34 PM   #40
ophic
ophic's Avatar
Tell them it doesn't have carbs and see how they respond. They'll probably be referring to the throttle bodies, and you can restrict pointies this way, but people on here have had problems with this - makes it run very rich and u get bad fuel economy.
The better way to restrict a pointy is to change the ECU.
