Old 26-05-10, 05:04 PM   #31
Miss_Undaztood
Default Re: neutral light does not work
Exactly, same as the diagram I have. So the black/white earth goes to the gear position switch, comes out of there to the relay as a blue wire, then the blue/black comes from the relay up to the neutral light, still earth.
The positive for the bulb will be wired inside the clocks or part of a circuit board.
Edit: Yup thats the exact diagram I was using.
Old 26-05-10, 05:09 PM   #32
Connect that blue/black to earth, light should illuminate. Simple.
If it does not your problem is within the light... probably that it is not getting power if you confirmed bulb works.
Sure I said this about 2 hours ago.
Old 26-05-10, 05:10 PM   #33
barwel1992
hmm ok then that i will try and run a lead strait from the battery to the bulb the problem i will then have is i need to mutilate the trail tech plugs because they force you to share ground and that wont work if you have to use a separate ground
Old 26-05-10, 05:12 PM   #34
That blue/black IS the ground for that fookin bulb
+ve terminal in battery
signal fuse
clocks
bulb for neutral light
blue black wire
relay
switch
black/white wire from switch
-ve on battery
That is order power follows.
Old 26-05-10, 05:15 PM   #35
barwel1992
the problem is YC if the blue/black is earth then i dont have a positive to give the bulb power unless i run the power from the ignition or battery
Old 26-05-10, 05:18 PM   #36
barwel1992
signal fuse
clocks
blue black wire
relay
switch
-ve on battery
i get it lol
i will go and try it but still not sure where to get power from
Old 26-05-10, 05:22 PM   #37
Find a wiring diagram or instructions or something for clocks.
Old 26-05-10, 05:23 PM   #38
I am surprised if clocks do not have this built in as the majority of bikes use same neutral light system.
If they do not have it built in there MUST be a wire for it!
Old 26-05-10, 05:24 PM   #39
Miss_Undaztood
Take your old clocks to bits and see where it takes it from originally by working back, or just take a tap from the red/white or orange/green I think the colours are. They both seem to be ign positives.
Old 26-05-10, 05:27 PM   #40
Use "signal" fuse IIRC.
Neutral Light for curvy ricky_t Bikes - Talk & Issues 0 15-03-10 03:38 AM
Neutral Light DarrenSV650S Bikes - Talk & Issues 3 09-05-09 05:12 PM
Me being a numpty - no neutral light and fi light is on Whitehouse SV Talk, Tuning & Tweaking 8 03-04-09 03:50 PM
Intermittent Neutral Light mikebrooman SV Talk, Tuning & Tweaking 2 19-02-09 03:28 PM
Neutral Indication Light? MitchC SV Talk, Tuning & Tweaking 6 01-04-05 08:15 PM
