Old 09-01-12, 12:19 PM   #31
Default Re: Fitting (Shoehorning) a Stebel Nautalus onto a Curvy
VWP is the devil, spend 30p here and there and the next minute it's £100!!!
The horn should be fine wherever if supported or on some sort of anti vibration mount. Andrew AFAIK any relays are external, the horns simply have a compressor motor with +ve and -ve terminals, mount relay wherever suits.
Yep!
Got it down £27 in the end as it was the bags of bullet connectors and sheaths that made it jump quite a bit. The cable tools didn't help
I'm going to have a proper look over the weekend as I did eyeball the front Cylinder mount as a candidate for the mount.
Originally Posted by punyXpress View Post
Just a thought, Chris:
Is there a frame tube that could be pressurised & then use that to blow the horn?
Eliminate electrics altogether.
Puny
Old 09-01-12, 12:36 PM   #32
MJC-DEV
MJC-DEV's Avatar
Picture of front pinch mount thanks to SVRider
horn mount by MJC-DEV, on Flickr
MJC-DEV is offline   Reply With Quote
Old 09-01-12, 09:46 PM   #33
Right here's my set up. Compressor sited under rear seat (little grey thing on left). Zip tied in place with a bit of pipe insulation to help with vibration. Tube goes from compressor to front fairing, wiring as per the diagram posted.
Seperated horn lives in left upper fairing, so light just held in place with a light metal strap, using the indicator mount.
Old 09-01-12, 09:52 PM   #34
Excellente lads
I've got a rough idea what I'm going to do now.
Old 09-01-12, 11:34 PM   #35
Nobbylad
Nobbylad's Avatar
I just mounted mine on some bits of strap ally on the rad/fairing mount as per the original pics on here somewhere. Has worked for 3yrs without probs and is full of carp from 36k miles of all weather riding...even the connectors are still functioning and they're rancid.
http://forums.sv650.org/showthread.p...ghlight=stebel
http://www.independentphoto.co.uk/me...ttingGuide.pdf
Old 22-01-12, 12:31 PM   #36
D'oh
I knew I forgot to order something! Fuse holder
It is safe to run the ground from the Negative battery terminal?
Old 22-01-12, 01:58 PM   #37
musne
I fit mine using a bracket that was drilled into a mounting bracket for the lowers of the bike (pics uploading now)
Didn't split the compressors or anything
Old 22-01-12, 01:59 PM   #38
musne
Old 22-01-12, 01:59 PM   #39
musne
Old 22-01-12, 02:00 PM   #40
musne
The relay was temporary attached to the bracket, but now it's moved to where the original horn was.
Stebel Magnum fitting questions. daveyrach SV Talk, Tuning & Tweaking 14 17-05-11 09:02 AM
Hiding a Stebel Nautilus on a Curvy maviczap SV Talk, Tuning & Tweaking 0 21-02-09 11:35 AM
Stebel Nautilus on naked...fitting help 600+ SV Talk, Tuning & Tweaking 15 15-05-07 09:47 AM
Stebel Magum Fitting on a Pointy. danf1234 SV Talk, Tuning & Tweaking 26 04-05-07 04:44 PM
Stebel Magnum horn - fitting Tigerrrr....... SV Talk, Tuning & Tweaking 3 23-09-06 09:45 PM
