#31 |
#32 |
All mine except the large white one on tank came off first day using hair dryer but that last one would not budge. Few weeks later after leaving bike in hot sunshine all day it peeled right off with WD40 taking the residue left behind away
#33 |
I starting taking my stickers off the tank about 5 weeks ago and it's still not off yet!!
I have had a hair dryer on it and it was burning my fingers it got so hot and the bloody sticker would only come off in 1mm by 2mm bits, after about 2 hours and hair dryer over heated and my fingers were red so I gave up with only about a 2cm removed. I am going to try the suggestion of petrol socked rag to see if that works. |
#34 | |
#35 |
Hey, did the petrol, rag, rub trick today. All sorted - it looks mint - thanks to all for the advice.
#36 |
use the hair dryer trick and then take 3M polishing compound with a microfiber towel and take the glue off worked great for me i use it on the entire bike to make it look better but if you do use polishing compound put a coat of wax back on to protect it. I recommend Maguire's NXT wax
#37 |
#38 |
i just got off the tank one... i used the hair dryer, but now i have blisters on four of my fingers... then i used gasoline to get off the glue. i wont be tackling the other two until me fingers heal... lol
#39 | |
won't boiling water damage the plastic fairing? I won't use a heat gun there. I was using a heat gun, but half way through the tank sticker it came to me that I'm heating a tank with petrol with a heat gun ![]() What temp. would you say is needed/safe? regs |
#40 |
Yes!!!
It worked! The tank is silver again ![]() One advice, if you're using boiling water: wear at least 4 latex gloves ![]() |
Pesky Warning Stickers | TheRamJam | Bikes - Talk & Issues | 5 | 23-03-09 03:35 PM |
Removing Warning stickers | jaromic | SV Talk, Tuning & Tweaking | 33 | 29-09-08 05:55 PM |
Warning Stickers....... | SoulKiss | Idle Banter | 9 | 17-06-08 02:35 PM |
stupid warning stickers | mario_dave | SV Talk, Tuning & Tweaking | 13 | 29-12-07 07:31 PM |
