Old 15-01-11, 06:23 PM   #471
PuggledPrune
Default Re: rear shock change
As soon as I wrote that, I knew it was a stupid question! lol Cheers!
Old 15-01-11, 06:26 PM   #472
Nobbylad
Nobbylad's Avatar
Stupid questions are the ones that don't get asked.
Old 15-01-11, 06:46 PM   #473
Wemoto can supply the OEM bolts if your not local to a Suzuki dealer
Old 15-01-11, 07:17 PM   #474
PuggledPrune
There's a K5/6 shock on fleabay just now pretty cheap, do you reckon it'll be too stiff? The K3/4's are all around the £80 mark just now...
Thanks for the links both of you btw!!
Old 15-01-11, 11:55 PM   #475
barwel1992
what side do the bolts go one again for a gixer thou shock ? took them out and forgot they have to gon in a certain way
Old 16-01-11, 12:15 AM   #476
Bolt goes in from left
Old 16-01-11, 12:19 AM   #477
barwel1992
cheers, should have made note
Old 16-01-11, 12:21 AM   #478
If you put it in from right you can't get the c**t out again without taking exhaust off
Old 16-01-11, 12:24 AM   #479
barwel1992
ahh right, didn't think of that
Old 17-01-11, 12:31 AM   #480
beno987
sorry i know its been asked hundreds of times but im thinking about doing the shock change i think i get this right. im 16st ish with leathers etc so a k4 or k5 gsxr 1000 shock will fit a k5 naked sv? i just need to put new gsxr bolts for the shock in and a bit of cutting? is that it or anything else need changing. thanks
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
