Old 16-04-09, 07:48 AM   #41
plowsie
Default Re: Bike Not Starting
Headlights cutting bike out, happened to me when my regulator was fecked...
Old 16-04-09, 08:00 AM   #42
21QUEST
21QUEST's Avatar
Plowsie, that was what I thought at first but I've already swapped the Rectifier, after he initial problem...which we thought fixed.
Unless the wiring issue is somehow(dunno how as I'm shoite with electrics : ) ) wrecking the Rectifier.
All this started with the break in wire. The bike had been perfect till the starting issue, whiich turned out a broken wire.
It's all a bit confusing but I reckon, something is not right(understatement huh :- D) with loom. The corroded wire was really bad....so the rest must be in a similar state of near crumbleness(is that a word lol) at the very least
Ben
Nemo me impune lacessit.
Old 16-04-09, 08:08 AM   #43
plowsie
Ben
Hmm, yeah i know what you mean, but remember when I bought Billy's bike? I had a reg/rec off you, then had to buy another aswell with new battery.
I know this sounds stupid but did you disconnect the battery when putting new reg/rec in? Its apparently a recommendation, I never did it with the first one I put in, but the second I did.
Have you had a voltmeter on it to rule it out?
I'm carp with electrickery too.
Old 16-04-09, 08:10 AM   #44
21QUEST
21QUEST's Avatar
That said, perhaps I'm just being really unlucky with the rectifiers.
Soooo I've just had a look and I've got another Rectifier I could try . I'd need ome help with wiring it, as it's from another bike
EDIT: Yup checked with Voltmeter after sorting out initial problem and reading wasn't as it should be. The second one was charging at 13.7 so 'happy days' , I thought.
Ben
Old 16-04-09, 08:12 AM   #45
plowsie
Ben
CBR one is seen as an upgrade.
As I always say when talking about reg/recs, I remember back to a convo with Spannerman in his garage...
CBR r/r work **** on CBR's
SV r/r work **** on SV's
However CBR r/r work well on SV's, and SV r/r work well on CBR's lol.
Old 16-04-09, 08:13 AM   #46
plowsie
Ben
As you say happy days, don't think it can be the r/r then.
Old 16-04-09, 11:17 AM   #47
Dave20046
Dave20046's Avatar
Or so we thought
Looks like like it's not fully sorted. My solution was to run a wire directly from the CDI end to the ignition end. I think the corroded wire I found was just the tip of the iceberg unfortunately....
Bike cut out yesterday again. Could bump start it but wouldn't run with headlight on. Everytime I switched the headlight on, it would cut out. made for an interesting ride.
Checking with a Voltmetre comfirm the Voltage stable, wiithout headlight on but flicking the switch on, made it start dropping....VERY FAST.
Errr summin aint right me thinks hehe. I should be doing a loom swap this morning. It's one off an S but that would have to do for the moment....gets bike working properly(I hope) atleast.
Dave, what year is your bike ?
Ben
1999 and yellow
I hate motorbikes.
Bike not starting. svdemon SV Talk, Tuning & Tweaking 15 22-08-08 11:29 AM
bike not starting Ash_sv650 SV Talk, Tuning & Tweaking 3 26-06-08 10:48 PM
Bike not starting. help. bad-sv650 Bikes - Talk & Issues 23 13-01-08 03:18 PM
HELP!!! BIke not starting!! riktherider SV Talk, Tuning & Tweaking 10 08-06-05 02:14 PM
Bike not starting. valleyboy SV Talk, Tuning & Tweaking 2 19-02-05 08:49 PM
