Old 28-04-09, 09:12 PM   #41
TheShadow
Default Re: Looking for some help with a shock
ermmmm .. 15mm is not even race spec. you have it wayyyyy to hard.. that's your static sag measurement.. i'm surprised you are not being thrown out the seat when you go over bumps..
please read from start to finish....
http://www.gostar-racing.com/club/mo...ion_set-up.htm
hope it helps
What i mean to say was the unloaded to fully loaded is 40mm> the normal to fully loaded is 15mm> plus i am unable to accurately measure this lot but it doesn’t feel right. You sit on the seat and it drops down a considerable amount.
Old 28-04-09, 09:17 PM   #42
yes so both measurments are wrong... you have from what you are saying is 25m static sag then 15mm rider sag...this should be the other way round..
if you have standard front forks you will end up see-sawing when you get to bumpy stuff. the back end will also go very light under heavy breaking..
to be honest with you i would soften up the pre-load some.. there is no point making the back end of your bike 'solid' if the front is 'soft'...
Old 28-04-09, 09:19 PM   #43
what do you weigh... just for referance
Old 28-04-09, 09:34 PM   #44
TheShadow
Front is not soft , front is 15w oil and hagon springs.
11 Stones ,
Old 28-04-09, 09:46 PM   #45
ok 1/2 a stone heavier than me... and my pre-load is almost all the way down... you have to remember you are fitting a shokky that is not designed for the SV.. the ZXR1000 is a big powerful sports bike.. the SV is not..
the ZXR shokky might feel soft but its not... it just takes care of the bumpy bits better than the naff stock SV shokky...
you have probably not set up the compression and rebound settings yet.. this will make a huge difference to the feel of the bike one you do.. remember thogh
Fast and Slow settings are not speed related... it is Rate related as in to how much the damper moves e.g. Fast setting will be more reactive.. or put it another way.. its like compressing a spring with your hand then either letting go (Fast) or controlling it with your fingers (Slow)...
its the same with H and S settings H does not mean Hard it means that it is controlling the rate at which the damper is moving out at the H setting the damper is moving Slowly.. at the S setting the damper is moving quickly...
if you already understand this then i'm sorry for re-iterating...
Old 28-04-09, 11:47 PM   #46
husky03
Originally Posted by TheShadow View Post
11 Stones ,
You eleven stone?-you sure wee man? maybe have guessed at a near ten but no eleven-must be your new boots eh
Old 29-04-09, 12:08 AM   #47
Luckypants
Luckypants's Avatar
Err that will increase both static sag and rider sag, so it's not the thing to do.
TBH 25mm static sag and then 15mm extra with the rider on sounds very wrong (the wrong way round as pointed out), but 40mm total sag is ok for road riding. I would definitely get all that measured again.
BUT if pre-load is fully wound on and an 11st rider rider is making the bike sag 40mm I would tend to agree that the spring rate is too low for the bike.
Old 29-04-09, 12:25 AM   #48
11 Stones ,
hmmmm.. well if husky is right and you are about 10-10,1/2 stone then you are same weight as me...
you must just like very stiff suspension...
Old 30-04-09, 08:22 PM   #49
Preload doesn't change the stiffness at all! It only varies the starting position of the shock, just because it sinks down more or less when you sit on it doesn't mean it's stiffer or softer.
SV650 K6 shock & GSXR1000 K4 Shock weecorey For Sale - SV's and SV related items 0 03-05-09 08:02 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
M10 55mm Shock bolt and nut for Kwak Shock Mr Speirs Stuff Wanted 3 24-10-08 12:00 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) alien19779 For Sale - SV's and SV related items 0 28-03-06 01:16 PM
