hi everyone,
Can anyone tell me whether a hugger from a 'naked' fit an 's' (2003)? I heard somewhere that the holes dont line up the same. Hope you can help Phil |
i couldnt say on the 650 but on the 1000 there are 2 diff sizes.
Hi Phil,
No it won't fit I'm afraid the holes are indeed different distance apart. I have a 2003 S and searched for ages until I finally found one on Ebay. You'll also have to be careful about trying to fit a hugger from later models - certainly with the OEM ones they won't fit as the K3 has a few subtle differences in dimensions to later ones. Hope this helps. |
the tool box is in the way on the newer models.
Cheers guys - much appreciated.. I'll have to keep on trawling..poss a little bit late to mention but I'm assuming theres no difference between the belly pans from the s to the naked??
Ta |
There may well be, IIRC the curvy has different length swingarms from the standard to the S model to soften the steering
Might be best to phone up one of the manufacturers and ask if theres different fitments
Apparently the S model K3 has only one brake hose loop and the naked has two. Why?
I recently swopped my Pyramid hugger for an Ermax one, and that fitted my K3 naked perfectly even though it came off a faired K3 S. The front brake hose loop fixing bolt on a K3 naked is the same distance from the end of the swingarm as the frontmost one on a K3 S. My pyramid hugger came with a god-awful nasty rusty steel bracket that wound its way round the swingarm. I replaced that with a lovely polished stainless one I made myself that fixed to the two bolts holding the brake hose loops. |
Abba Stand Fittings - For Curvy | Demonz | Stuff Wanted | 5 | 29-07-09 12:59 PM |
02 carbs and Carb Fittings | drag | Stuff Wanted | 1 | 01-02-08 01:12 PM |
Bulb fittings | Jester666 | SV Talk, Tuning & Tweaking | 2 | 22-05-07 07:57 PM |
Exhaust Fittings | BLK SV | Exhausts | 3 | 09-10-06 01:28 PM |
Exhaust fittings | Bear | Exhausts | 0 | 30-07-06 02:47 PM |
