Old 12-03-08, 08:53 PM   #1
Mark_h
Mark_h's Avatar
Default SV1000 exhaust gaskets
Should there be a gasket between the pipework and the end can where the 4 bolts fix on or should it just be metal to metal. I'm getting some leakage at this joint and not sure if perhaps there should have been a gasket.
Previous owner had cans off and on regularly so if there was one originally it may well not have made it to the end.
Minister for Sustainability
Old 12-03-08, 09:04 PM   #2
mattSV
mattSV's Avatar
Default Re: SV1000 exhaust gaskets
I use cheap as chips B&Q clear monkey spunk on mine
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 12-03-08, 09:15 PM   #3
Mark_h
Mark_h's Avatar
OK, gimme a clue? is B&Q your local zoo? Do I have to take my own primate porn?
Old 12-03-08, 09:24 PM   #4
Otherwise known as bathroom sealant
Pattern exhaust joint gaskets? tonny006 SV Talk, Tuning & Tweaking 6 21-01-09 10:24 AM
SV1000 Exhaust Rokkan Stuff Wanted 13 23-11-08 03:44 PM
SV1000 Exhaust Question MR UKI (1) SV Talk, Tuning & Tweaking 17 02-08-08 06:21 PM
sv1000 exhaust on a sv650? toyotafj40s SV Talk, Tuning & Tweaking 5 21-08-06 02:52 PM
Fitting exhaust gaskets andyaikido SV Talk, Tuning & Tweaking 4 19-02-06 05:29 PM
