Old 04-05-08, 11:55 AM   #1
Tomis
Default Bent brake pedal
Has anyone tried to straighten a bent brake pedal and if so what method did you use please.
Old 04-05-08, 12:05 PM   #2
richbeales
Default Re: Bent brake pedal
I've also bent my brake pedal, it still works, and have been advised that as it's aluminium there's a very high chance of it snapping if you try to bend it back again.
The only problem I have with it being bent is that it seems to be slowly loosening the footpeg (over several months / thousands of miles) so the whole assembly will need replacing at some point.
Old 04-05-08, 04:05 PM   #3
ranathari
Heat it with a blowtorch and then slowly bend it back.
Old 04-05-08, 09:04 PM   #4
Rich
Rich's Avatar
Yeh i did the same a while back and used a blow lamp to heat it up where it bent and hit it with a hammer until it eventually got back to shape..
http://forums.sv650.org/showthread.php?t=92695
RIP Hovis - Unlucky Boyo
Old 05-05-08, 02:14 PM   #5
It's alloy, so it gets brittle before it melts.
Better to heat it up, allow it to cool, then bend it.... worked on a gear lever anyway
Old 05-05-08, 04:10 PM   #6
Tomis
Thanks but how hot do you get it ? Do you do the spit test or is that too hot ?
K5 Brake pedal jamesobrady Stuff Wanted 1 20-03-09 08:02 PM
Straightening of bent rear brake pedal? husky03 SV Talk, Tuning & Tweaking 4 06-05-07 10:23 AM
Brake Pedal Steve226 SV Talk, Tuning & Tweaking 11 18-11-06 06:00 PM
Can bent brake discs be straightened ? valleyboy Bikes - Talk & Issues 12 16-12-05 07:08 PM
Brake pedal drumwrecker SV Talk, Tuning & Tweaking 4 16-05-05 04:03 PM
