Old 06-05-08, 10:50 AM   #1
DanDare
Default Trouble selecting 2nd Gear
Morning All,
My K4 recently went for its first MOT and they have adjust my clutch lever.
It used to bite far out but now they have adjusted it so that it bites almost immediatley after releasing it.
As such I cannot always engage 2nd gear let alone neutral. It is stiff as a***holes. All the other gears are Ok, just going from 1st into 2nd.
When I mean stiff, Its difficult even stood still using my hand to yank it up.
What is causing this and how easy is it to adjust?
Do I need to adjust the thread on the bar on the rear set?
Cheers in advance
Dan
Old 06-05-08, 11:06 AM   #2
sv650k4
Default Re: Trouble selecting 2nd Gear
its probley something 2 do with the gear shift set up.
is it just standard pegs/hangers you have?
Old 06-05-08, 11:20 AM   #3
DanDare
Yep, all standard set up
Old 06-05-08, 12:33 PM   #4
sv650k4
a ryt sometimes if people put after market rear sets on they put a bit on wrong and sometimes makes gear changing very stiff.
but even with the standard ones it could still be done probley have you have any of the gear shift off lately???or was the bike working ok then it just started 2 get stiff changeing gear??
Old 06-05-08, 12:36 PM   #5
Spikenipple
Spikenipple's Avatar
Why did they adjust your clutch anyway? Did you ask them to?
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 06-05-08, 12:48 PM   #6
hovis
try an oil change?
Old 06-05-08, 01:34 PM   #7
DanDare
To be honest I never queried the MOT people adjusting it as I thought it would be better than before.
Its since the MOT I have had the problem, it was absoultley fine before. It has had a service recently so the oil should be good.
I just wondered if there was a simple solution before I take it to my Suzuki dealer to look at.
Old 06-05-08, 01:45 PM   #8
blueto
i would take it back to who ever adjusted it to begin with and show them the problem. Then ask them nicely if they would like to put it back to how it was before please.
Old 06-05-08, 01:56 PM   #9
arenalife
The clutch isn't disengaging fully probably, it shouldn't be biting as soon as the lever is released. The more usual and recommended adjustment is how it was before.
Old 06-05-08, 03:36 PM   #10
Try take a little slack out of the cable and see if it improves. Use adjuster on the bars, just a couple of turns.
Gear Trouble. Sally SV Talk, Tuning & Tweaking 24 21-12-08 01:40 AM
Engine stops when selecting a gear DanF SV Talk, Tuning & Tweaking 6 22-02-07 06:49 PM
gearbox not selecting gear correctly. DoubleD SV Talk, Tuning & Tweaking 5 30-08-06 02:22 PM
gear trouble Torn SV Talk, Tuning & Tweaking 8 31-03-06 07:09 PM
2nd gear trouble jonnyb SV Talk, Tuning & Tweaking 6 17-04-05 04:35 PM
