Old 01-07-08, 08:08 AM   #1
svrash
Default Curvey engine with cam swap, ignition advancer and detent arm
K3> intake cams, curvey intakes on the exhaust side (revs right the rev limiter)
ignition advancing woodruff key (advances the igniton 4 degrees)
factory pro detent arm and spring (changes gear quicker)
Iridium spark plugs
Stainless steel bolts everywhere
about 8k, oil changed every 6 months, due an oil change now and tappest shims need checking
?250 + postage, pick up welcome
Old 07-07-08, 11:26 AM   #2
svrash
Default Re: Curvey engine with cam swap, ignition advancer and detent arm
bump
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 3 18-03-07 12:15 AM
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 22 08-03-07 03:46 PM
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 6 07-03-07 10:59 PM
Ignition advancer? sixstring SV Talk, Tuning & Tweaking 19 22-07-06 06:39 PM
Ignition advancer?????? bobbydee SV Talk, Tuning & Tweaking 10 16-03-05 06:04 PM
