Old 03-07-08, 12:46 PM   #1
Default Not the normal type of indicator flash rate problem....
I know that when most people get new LED indicators, they post up asking how to slow down the flashing rate, but this isn't exactly that problem
I have just put on new rear indicators with 25W 8 Ohm resistors. And the flash rate is fine, for about 5 flashes. Then it suddenly speeds up again and goes too fast. But then if I switch them off, wait a bit then try again, the same thing happens - fine for about 5 flashes then it goes crazy.
Only thing I can think of is that the resistor is heating up maybe? But I don't see how it would suddenly get so fast. I would have thought it might gradually get slightly faster.
Anyone have a clue what's happening?
Old 03-07-08, 12:47 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Not the normal type of indicator flash rate problem....
Probably is a thermal issue
Should have gone with a relay
Old 03-07-08, 12:50 PM   #3
chakraist
I have the same issue with my left indis- the right one flashes too fast but that's because I caught the right one on my garden gate when leaving my house one and it stopped working. I need to get all the wires checked
Old 03-07-08, 12:53 PM   #4
I didn't think that was possible on the sv. Do you know where they sell them?
Old 03-07-08, 12:58 PM   #5
Baph
You said the rating of the resistors, but what material were they made of?
I'd bet a shiny new penny that the resistors are over-heating after a couple of power cycles. There will be a critical temperature, that when reached, will cause the resistors to have less resistance than a chocolate fireguard has to heat.
I know Halfords did sell a universal 12v indicator relay kit.
Old 03-07-08, 12:59 PM   #6
SoulKiss
SoulKiss's Avatar
There isn't a specific one for the SV, I used a Honda one from Halfords and just modfied it - but dont ask me how, I cant remember and I dont have the SV anymore to check.
A search on here for "flasher relay" came up with this - which I THINK was the guide I used
http://forums.sv650.org/showthread.p...=flasher+relay
Old 03-07-08, 01:09 PM   #7
They look like this
I might just have to pop along to halfords just now
Do you need one relay for the front and one for the back? Or does the one do both?
Old 03-07-08, 01:17 PM   #8
Baph
They look like this
Ooo, you paid big money for sh*te resistors. That outer casing (for mounting) will cause them to over-heat quickly when used on-off for indicators. They were probably designed for in car audio purposes (given the gold plate).
One relay fits all (subject to appropriate manufacturer). Left/Right/Front/Back, doesn't matter.
Old 03-07-08, 01:28 PM   #9
Should have asked before I ordered them.
Yeh because I have resistors on the front indicators because they are a smaller bulb. They are the normal looking resistor and they have been fine for ages
Oh well, live and learn. I'm off to halfords to get a honda relay, then I can remove all the resistors. And hopefully flog those fancy ones on ebay
Old 03-07-08, 01:31 PM   #10
Baph
Another case of Keep It Simple Stupid
LED Flash rate relays... DF! SV Talk, Tuning & Tweaking 4 17-09-08 06:47 AM
LED indicators and flash rate Quiff Wichard Bikes - Talk & Issues 12 28-05-06 11:09 AM
Led indicator flash rate TC3 SV Talk, Tuning & Tweaking 16 11-12-05 08:15 AM
LED Indicators - Flash Rate mastiffmat SV Talk, Tuning & Tweaking 3 09-11-05 04:54 PM
Flash rate Problems?? (Non LED) Sledgehammer SV Talk, Tuning & Tweaking 7 15-08-05 08:45 PM
