Old 03-09-08, 11:24 PM   #1
Kemp10
Default Best Rotors?
things are finally going better in the area of cash my way with my most recent change of employment and raise, so i can finally stop neglecting my baby.
i have an k6 sv650s and want to begin with new rotors.
what are the best of the best?
Old 03-09-08, 11:27 PM   #2
Stu
Trinity
Stu's Avatar
Default Re: Best Rotors?
What are rotors? brake discs? If so that's not a usual starting point for upgrade
Old 03-09-08, 11:36 PM   #3
lukemillar
Helpful Stu!
Yes, rotors are brake discs. I don't know loads but I think at the highest end you get carbon discs which are only for race use as the need to heat up before biting. These are also very expensive! Next one down are ceramic discs (still very expensive), then iron discs, then your standard stainless discs.
Have a look here:
http://www.ferodobraketech.com/
With the SV, the most people have tended to do with the brake disc, is fit wavey stainless discs which don't really offer much advantage over standard disc except maybe extra cooling (larger surface area) and looks.
http://www.jhsracing.co.uk/brakes.htm
Old 03-09-08, 11:43 PM   #4
OEM ones, you know you're getting something useable which is more than a lot of aftermarket discs.
Old 03-09-08, 11:44 PM   #5
Stu
Trinity
Stu's Avatar
well I wasn't sure, but I thought so
To improve the brakes of an SV you want to put 4 pot calipers on, like from a gixxer. Check out the adapter plates in the for sale section from dirtydog if you don't want to do the whole front end conversion.
helpful enough?
Old 03-09-08, 11:44 PM   #6
Yeah, rotors is what our US friends tend to call discs. Stu's right though, it's not a very good place to look for an upgrade. They're expensive, and though you can save a little weight or get some extra brake, it's not that big an improvement and more a "last bit of performance" than a "first mod". Unless of course yours are worn or bent of course.
Thing is, if you want to mod up an sv, a GSXR swap will probably be on the cards, and if you think you might ever do that then fettling the stock brakes is daft- your discs don't have very good resale value if you have to change them. And tbh, the cost of an aftermarket brake disc set is more than the cost of a GSXR front end, which will make about 10 billion times as much of a difference for you.
Brembo are great but if memory serves they have a lot of iron in their metal, which is good for braking but means they rust fast, not nice on a street bike. I won't ever put EBC Prolites on a street bike again, they're terrible in winter for corrosion- they always look bad, but also they rusted to the pads literally overnight. Braking are nice, OEM quality and a good look, but not really an upgrade IMO.
I want to try Grimeca, they look good. They do a lot of OE as well.
Old 03-09-08, 11:46 PM   #7
I've heard different to "OEM quality" about braking ones.
Old 03-09-08, 11:55 PM   #8
Mine were very good. Rusted slightly over winter but not serious, no worse than the OEM Honda I have on it now. Anodising etc was all first class, and they didn't have any wear issues. I got them used as well...
Old 04-09-08, 07:42 AM   #9
Supervox
No more Mr Nice Guy
Supervox's Avatar
I bought a set of braking 'Wavy' discs 3 years ago for my Thou & they have been fine - no serious rust or undue wear issues - and they look the 'dogs' too !!
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 05-09-08, 03:28 AM   #10
Kemp10
ah thanks guys, never even heard of the gixxer swap. yes i am from the usa, and we call them rotors
sorry for the misunderstanding, i tend to forget this forum is based out of the uk, lol.
the only reason i was starting with the rotors (thinking about it, it does sound weird to start there without knowing my original intent) is because they are a bit rusted.
thanks for all your comments, i wanna look into this gixxer switch.
Brake rotors parkinmj SV Talk, Tuning & Tweaking 3 14-02-09 10:13 AM
brake rotors crankcase Bikes - Talk & Issues 2 28-10-07 11:14 PM
front rim (with rotors) sv650 k3 magnusk Stuff Wanted 0 26-06-07 08:57 AM
brake rotors kcowgergmm SV Talk, Tuning & Tweaking 1 11-01-07 01:53 AM
brake disc with aluminium rotors mart SV Talk, Tuning & Tweaking 13 19-06-06 10:52 PM
