lately my sv has developed what appears to be noisy bearings. when i roll it out of the house to start i can hear a rubbing noise which sounds like its coming from the front. today when out i think i could hear a rubbing noise when cruising(kinda hard over the beowulf
The rubbing could be the front calipers slightly seized ...it happens easily in this wet weather, as for the sudder, if you were breaking hard this can cause a shudder effect on the front end, i know i still get it on mine and i've gsxr calipers on now.
Last thing that comes to mind might be the head bearing, but thats more of a movement feeling than a shudder .. |
#3 | |
+1 brakeing hardish can cause a slight shudder and the binding could be calipers/pads etc... tho if you have a front paddock stand bump the front wheel off and check the bearings then you will find out for sure. ![]() |
#4 | |
I would suggest getting that front wheel in the air and giving it a wobble side to side see if there is any play. Also do the good old pulling pushing on the forks with the front wheel in the air see if the head bearings are shot
Could be calipers need a rebuild, wheel bearings, spin front wheel and listen for a noise. Bearings rumble. Will also show any excess resistance from brakes
(99) Curvy SV650s 2 x Front Bulbs & 2 x swing arm bearings | vardypeeps | For Sale - SV's and SV related items | 3 | 09-05-09 05:49 PM |
bearings | sv_rory | SV Talk, Tuning & Tweaking | 5 | 12-02-09 07:29 PM |
Front wheel bearings | Slim666 | SV Talk, Tuning & Tweaking | 23 | 30-04-08 08:29 AM |
1200 Bandit FRONT wheel bearings | Blue_SV650S | SV Talk, Tuning & Tweaking | 3 | 15-02-08 09:22 AM |
Front wheel bearings - £50 fitted at Hamilton MC | Dirty Baz | SV Ecosse | 6 | 31-01-06 10:47 PM |
