Old 23-05-09, 07:44 PM   #1
DaveP
Default oiler not oiling?
Just fitted the scottoiler to my bike, But it does not appear to be working.... as far as i can see its fitted correctly.
Any suggestions as to why it may not be working? any common mistakes??
cheers
Dave
Old 23-05-09, 07:46 PM   #2
Default Re: oiler not oiling??
you need to purge the system of all air... if there is air in the pipes it wont work properly ...
you have connected the vacuum pipe?
Old 23-05-09, 08:08 PM   #3
DaveP
yes... all pipes connected and no air in the pipe at all....
how long should it take for the feed to begin to drip??
Old 23-05-09, 08:27 PM   #4
well when you start the bike it should drip every 10 seconds or so... you have been running the bike to check haven't you....
Old 23-05-09, 08:29 PM   #5
fizzwheel
fizzwheel's Avatar
You need to twiddle the dial on the end of the resevoir to the "prime" setting. Start the enigne the oil will flow slowly along the tube to the dispenser down by the rear sprocket.
You can hurry the process along by doing the above and blowing through the breather tube.
Just be patient with it, if you have it all connected up properly then it will start to flow.
Old 23-05-09, 09:26 PM   #6
mustnt grumble
Really? I thought 1-2 drops per minute was recommended.
Old 23-05-09, 10:21 PM   #7
DaveP
well i checked and double checked and everything i had done appeared correct.. then i noticed something... It didnt seem right... (Now bear in mide that this is the first time i have ever seen one of these thing up close.)
Turns out that the steel bar has jammed into the end of the Black plastic nozzle inside the pipe!!! I was under the impression the metal pipe was hollow as this is how it was when i opened the box...
sorted now.... Done!
Cheers guys
Dave
Old 23-05-09, 11:33 PM   #8
Jamiebridges123
Scottoilers are incredibily simple. Took me 15 minutes to install...
Hardest thing was bending the metal thing and the little black injector nozzle so they stay on the bloody sprockets! ARGH.
Old 26-05-09, 09:32 AM   #9
Luckypants
Luckypants's Avatar
Well done Dave, was looking at your chain the other day thinking 'Tut tut!'
how much did you pay for your Scotty by the way, looking for one at the moment but £70 odd seems rather steep.
Chain Oiling G SV Talk, Tuning & Tweaking 24 14-05-07 01:09 PM
oiling bmc filter 01 sv650s SV Talk, Tuning & Tweaking 3 29-12-06 09:53 AM
Chain Oiling krhall Bikes - Talk & Issues 35 11-12-06 02:49 PM
oiling chain hovis Bikes - Talk & Issues 22 22-10-06 09:47 PM
oiling cables? kwak zzr SV Talk, Tuning & Tweaking 6 19-03-06 03:23 PM
