Old 21-06-09, 05:31 PM   #1
lazymanc
Default Clutch / generator cover gaskets
K3 pointy - do you need to put any kind of sealant on these paper/metal gaskets or do they just fit straight over the dowels and whack the cover on?
Haynes doesn't mention any sealant but I thought I'd ask.
lazymanc is offline   Reply With Quote
Old 21-06-09, 05:33 PM   #2
flymo
flymo's Avatar
Default Re: Clutch / generator cover gaskets
No sealant, just get the existing surfaces nice and clean before you refit with new gaskets.
I use a small peice of green pan cleaning pads from the kitchen, works perfectly to clean the mating surfaces.
Old 21-06-09, 06:06 PM   #3
lazymanc
Ok, and how about the o-ring seals for the coolant channels to the water pump? That says use suzuki bond - what's a good (cheapish) alternative?
Old 21-06-09, 06:11 PM   #4
flymo
flymo's Avatar
If the O rings are in good condition I wouldnt bother, I didnt last time I replaced gaskets. A smear of vaseline should ensure they get a good seal to start with.
Old 21-06-09, 06:29 PM   #5
Jamiebridges123
RTV Silicone stuff never goes a miss..
Old 21-06-09, 06:46 PM   #6
lazymanc
Ok cool, cheers guys.
Finally got my engine back in the frame, bit confusing trying to work out where all the pipes and wires go but I'm getting there with a combination of haynes / microfiche and a process of elimination
Fitting new cylinder head cover gaskets flymo SV Talk, Tuning & Tweaking 12 05-10-10 08:48 AM
Leaking rocker cover gaskets flymo SV Talk, Tuning & Tweaking 5 18-03-09 11:38 AM
Paint on Generator Cover Graciepants Bikes - Talk & Issues 67 06-03-09 07:26 PM
Clutch Gaskets? kellie000 SV Talk, Tuning & Tweaking 3 05-01-07 11:15 AM
Generator Cover Removal chicklemass SV Talk, Tuning & Tweaking 2 23-08-05 07:57 AM
